Originally Posted by
Up2DTime
I have 30 service records from audi / porche dealerships ranging from oil changes to fuel injectors. i didnt see anything about carbon build up. Its a 3.2 fsi. Thanks for your responses
Carbon buildup would be of a small concern if it has never been cleaned. There are plenty of forum members who have done it as a DIY so depending on how inclined you are, you can probably do it yourself for a minimal expense.
The achillies heel of the motor is the timing chains/tensioners/guides. As these motors are chain driving, Audi states they are "maintenance free" but nothing ever is; chains stretch, plastic guides degrade and become brittle, etc. When they fail, it generally results in a catastrophic engine failure (bent valves, busted pistons, etc).
When you started the car, did you here a rattle? Was the engine cold when you started it? The timing chains are sandwiched between the engine and transmission so it would sound like it is coming from the back of the motor. A slight rattle that lasts for a second or two is ok. Any prolonged rattling and I would walk away from the car and look for a different one.
