Results 1 to 22 of 22
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Just added chipwerke box to stage 2 car....
    I am new to this car so I am reading threads and trying to catch up on this chassis. My car is stage 2 custom tuned with smaller pulley. I decided to add the chipwerke box for extra performance and am curious if what I am seeing is correct? There is definitely a gain in performance, mostly noticeable in higher rpms from 5K-7K. Boost pressure seems the same or maybe a little less so I'm not sure whats going on there. When I ordered the box I asked them to configure it 3-1. If I decide I want to change that or check that its set there how do I do this? Thanks for any input/help. Car is only making 12psi-14psi btw, is this normal for a stage 2 pulley'd car making 415whp? Thanks
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Deactivated Three Rings
    Aug 24 2015
    Is this safe? Wouldn't normal stage 2 tune already up the boost level?
    Sent from my iPad using Tap,Tap,Tapatalk
    Mar 21 2015
    Theres a couple guys running it with stage 2 now, Leo is one I believe.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Most likely the CW is keeping your bypass valve closed more than what your tune is suggesting. You can open the bottom of the chipwerke box by taking out those 2 screws.
    Sent from my SM-G925V using Audizine mobile app
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    Just remember that if you're logging your car using VCDS, your boost pressure figures will show less than what they actually are... overall your max boost will not change (14-15 PSI) but it will close the valve more than before which will help lower the amount of boost bypassed under partial acceleration and probably extinguish any bypass at WOT
    Apr 05 2016
    Portland, OR
    You can pull the cover off the CW and change it.
    Just make sure to log.
    I have mine piggy backed on my stage 1 tune currently.
    Use 2-1 on pump gas and 4-1 when I mix.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by ModItNow View Post
    exactly .. some tuners tune conservative .. that means any first sight of something going wrong it opens the bypass valve and bleeds boost to be on the safe side.. the CW box is going to tell the ECU to ignore it.. everything's fine.. just keep on boosting.. so OP if you're in ideal conditions where the ECU doesn't need to dial it back.. you will likely see the same performance .. Loe is running the CW Box on top of his Stage 2 because he has dual pulley's .. so where the dual pulley is making more boost than the tune on Stage 2 is created for the CW box will say yes yes go for that boost where as the ECU will say Shut it down.. we don't need anymore
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 12 2006
    Michigan
    Okay that all makes sense except that I am not making more boost with the chipwerkes box, I am actually making a little less. I have a larger crank pulley that I will get on soon but still waiting on my VCDS cable to come so I can see where its at before I add more.
    Veteran Member Three Rings ShopVac's Avatar
    Feb 02 2016
    BMW M4 Comp / Abarth 124 Spider / RDX A-Spec / Jetta / Elantra
    Pittsburgh
    Quote Originally Posted by elijahallen View Post
    I'm not sure you're 'actually' making less, as much as CW may be telling the system you're making less to keep the bypass valve closed. I'd be concerned that it may be eliminating your safety net though.
    I'm sure you're getting some performance out of it...just don't know at what cost.
    There were folks doing this in the BMW world too...with the JB4 and JB+. I think Burger Tuning ended up even selling the something similar to the JB+ add on to the JB4 under a different name.
    __________________________________________________ _____
    Proud owner of four turbos and one supercharger.
    Apr 29 2013
    Detroit, MI
    Yeah, the CW box is fooling the MAP sensors and telling them you have lower boost than actual, which is why you may be seeing slightly less in VCDS. Ideally it would read the same on VCDS and you'd be making a certain amount more for real with the CW, but with the actual amount being higher, the tune may be pulling boost a little bit due to some other factor, such as IATs.
    2018 S4 8AT
    2012 S4 6MT
    2006 S4 6MT
    2000 S4 6MT
    Nov 12 2006
    Michigan
    Right now I don't have the VCDS cable but I do have the P3 cars vent gauge with boost, battery voltage, air temp, exhaust temp, 0-60, coolant temp, and ignition timing. That is where I am reading the boost, in 3-1 it averages 12.6-13psi at 6800rpm and at 4-1 setting its pretty much the same without a noticeable gain in performance. I have read of several people running quite a bit more boost then this with similar setups so I am just trying to get a feel for why mine isn't running more or does this gauge read the map signal and its not real time with the CW?
    Mar 21 2015
    ^P3 is requested boost not actual. You need a boost tap to get the actual reading on the P3
    Nov 12 2006
    Michigan
    Ok great, thanks, I will get one in and see where its at.
    Apr 05 2016
    Portland, OR
    P3 will read low with the CW installed as will VCDS.
    I'm kind of surprised you are not running into some DTC or CEL running it at 4-1.
    Doing a hard pull in mine with the settings too high will either throw a severity 2 DTC(no light) or a Severity 1 CEL(light on dash).
    Nov 12 2006
    Michigan
    Quote Originally Posted by whiped View Post
    What oct fuel are you running? I also am running meth injection so that might help a little to, maybe I should try 5-1 haha, its hard coming from a 600hp B5, these cars feel so slow :-(
    Apr 05 2016
    Portland, OR
    Normally just pump. (92)
    I've mixed in some E85 for fun.
    Seeing as you already have upgraded cooling you will probably be fine. (I have my AWE Coldfront kit sitting in my garage currently)
    What Meth kit are you running? Where did you add the taps? Pics of your setup?
    FWIW, the DTCs I was getting were due to not being able to match the request boost.
    Geoff
    Nov 12 2006
    Michigan
    Past owner did the AEM water/meth and has it tapped right behind air filter. Seems like a bad spot to me but haven't had time to research where people are tapping theirs. I would like to see it tapped in a hot spot so water/meth atomizes right away.
    Apr 05 2016
    Portland, OR
    I wonder why they did so close to the filter...
    I know S4matty has it spray after the TB. I was thinking about adding a kit and having the nozzles right before the TB because I don't want to drill holes in the actual charger.
    Where do you have the tank for it?
    Geoff
    Nov 12 2006
    Michigan
    It uses windshield washer fluid reservoir, this is nice because you get the heads up when fluid is low. In my B5 s4's I just sprayed windshield washer fluid with no issues but haven't tried that in this car yet.
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I'm not sure what chipwerke you bought (stage 1 or 2) but you should be running the stage 2 mapping to stack it like that.
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hi,
    Definitively, i suggest you to do some logging.
    I don't understand why you would need a CW with a simple Stage 2 tune (ie. no Dual Pulley).
    A proper tune should keep the by pass closed even at high rpm. So if so, i don't understand why you would have extre performance... except if the CW act also on the timing request via boost pressure manipulation.
    Please excuse me if i've missed Something.
    BR
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Nov 12 2006
    Michigan
    I bought a larger crank pulley at the same time as I bought the CW and just installed the CW first since it was easy. Crank pulley will go on soon. The CW is the stage 2 version.
