Page 1 of 4 123 ... LastLast
Results 1 to 40 of 133
    Established Member Two Rings will.bates94's Avatar
    Jul 17 2012
    United States
    3.0 Intake Manifold questions
    Just finished soaking the intake manifold for two days now in degreaser and it came out spectacular. My next issue to tackle now is the broken runner actuator within the manifold itself. I'm going to attempt repairing it myself with a piece of metal rod to secure it to the actuator.
    If I can't get the runner fixed how bad will it be to run the intake manifold without it? I'm sure I'll lose a lot of bottom end torque but is that it? I don't want to pay 500+ for a new actuator unit and I can't even find used ones.
    2018 TT-RS /// Unitronic Stage 1+ ECU, Stage 2 TCU, Midpipes, 4" Inlet /// 034 Trailing Arms, RSB, Rear Subframe Inserts /// Carbotech 1521 & XP8
    Aug 26 2005
    The actuator is outside the manifold, mounted on the front, not inside. Are you asking about the long cylindrical runner change over valve inside the manifold? Without the actuator, the change over valve can't move between low speed torque and high speed power settings.You can select one position or the other, and lock the change over valve in that position. I think setting to the low speed torque position would be the best of the two for daily street driving.
    Vorsprung durch Technik
    Jul 17 2012
    United States
    Yeah I'm referring to the cylinder within the manifold itself. Here is a picture to show what I'm dealing with.
    Jul 17 2012
    United States
    So my plan was to fit a metal rod into the little shaft in the picture and then bond it to the actuating unit. Going to use JB weld most likely.
    Aug 26 2005
    Yeah, that is the typical failure mode for the actuator. If you don't want to repair the actuator to change over valve coupling, either leave the actuator off the manifold and pin the change over valve into the low or high speed position. Or install the actuator and disconnect the vacuum hoses from the actuator diaphragms. The reason the actuator coupling fails, is due to the change over valve getting sticky and hard to rotate in the manifold, overloading the coupling.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    When you have it set in one position, you'll lose low end torque or top end power. Personally, I'd leave it at the default setting for better torque at low RPMs. Other than a power curve change, there shouldn't be any other issues.
    Jul 17 2012
    United States
    Update thus far.
    Tapped the center of the shaft with a 5/16 24 tap and I will be going to the hardware tomorrow to grab a nut that will fit within the actuator itself.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Damn actuator valve. I said f it and bought it new. Mine disintegrated with plastic pieces all in my intake.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jul 17 2012
    United States
    I may design one up before I put it back together in solidworks so that way I'll have a metal one in the future
    Veteran Member Three Rings pablolizarraga's Avatar
    Jul 18 2014
    "Hers": SQ5 His: 1966 Ford Mustang Coupe, 1965 Ford Mustang Fastback
    Los Angeles, CA
    Good to see others working on the 3.0! I'm learning a lot from you guys. Because of the info here, I recently took the intake manifold as a result of a leak in one of the nipples of the coolant pipe. While I was in there, I also installed the 034 spacers, did most of the hard to reach vacuum lines, and removed the change over mechanism to inspect it. It didn't look as bad as I expected and it did rotate when I tested it by sucking on the end of the vacuum line when removed from the changeover valve (N 156). However, after reinstalling and revving to 5k, the changeover valve did not rotate. The valve still requires quite a bit of force to get it to rotate by hand. When I get more time, I'll try cleaning it like you did. This is what changeover valve looked like.
    And this is where it's currently stuck; which I believe is the high RPM position?
    Good luck in the repair! Looking forward to seeing what you were able to come up with.
    Jul 17 2012
    United States
    Quote Originally Posted by pablolizarraga View Post
    Yeah I ended up ditching the idea of the threaded bit because it would create too much depth. I ended up lining it up and jb welding the inside of it and it works perfect now. This is what the manifold looks like now and I'll post pics of the change over cylinder in the AM.
    May 22 2012
    FAIRBANKS/AK/USA
    I would like to set mine up in the low rpm position until I can afford the new change over cylinder.
    What position is that if you are facing the front of the engine?
    2002 A4 3.0 MT
    Senior Member Two Rings DJHoro's Avatar
    Dec 16 2014
    Fresno
    Would revving it to 5k make the changeover valve rotate? You dont have to be in motion?
    Jul 18 2014
    Los Angeles, CA
    That's looking really good. Glad the jb weld worked out! I'm guessing that mine is stuck on the high rev position based on a couple of videos. But here's the best one.
    https://youtu.be/oSeBf7pFCpM
    @DJHoro Based on the videos and some research, it seems you don't have to be in motion for valve to rotate.
    http://workshop-manuals.com/audi/a4_...ing/page_2097/
    I'll be troubleshooting mine starting by cleaning actuators and rotating valve.
    https://store-lyr7tp5r.mybigcommerce...d_Link_DIY.pdf
    Keep the updates coming
    Aug 27 2013
    Philly
    Damn, that first video is making me think something is wrong with my 3.0. Mine is always sitting in the resting position and I don't think it opens up to the low end position when the car is started. I'll be checking this later today. My vacuum lines are all in good shape, so I wonder what could cause this. Maybe broken wires in the actuator drive? Bad vacuum?
    Jul 18 2014
    Los Angeles, CA
    As suggested in the work-shop manual, I would start by trying to move/push the rods manually. If they're difficult to move, chances are that gunk has built up and prevents the rotating valve from turning. I was unable to move mine by hand. Don't use tools to turn it because you'll break plastic rods. I finally saw valve rotate when I tested the vacuum line removed from the N-156 valve (#1 in diagram) by sucking on it like a straw and it moved a little!
    https://docs.google.com/file/d/0B-07...iletype=msword
    Until I clean out valve and inspect actuator I plan to disconnect vacuum line leading out from N-156 and trying to devise a way to lock actuator into low RPM setting (as recommended by diagnosticator). Otherwise, risk arms and valve being stressed and having to go through what will.bates94 is going through.
    Aug 27 2013
    Philly
    Thanks for the tip! Last time I checked, the arms moved without issue. I cleaned my intake and replaced the actuator last winter with a known working unit.
    Mar 21 2016
    69 Nova
    California
    Wow, I'm gonna have to see if mine move that easily now...
    12 S4 Quattro 6 Speed
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    19 Sportster 883
    Jul 18 2014
    Los Angeles, CA
    You may have to check the valves to which the vacuum lines connect. Don't know how to do this but I found this guide on the interwebs:
    https://www.dropbox.com/s/h1pzsic1hs...0over.pdf?dl=0
    In the meantime I came up with a way to lock valve into low RPM setting;
    1) Disconnect hose
    https://drive.google.com/open?id=0B-...HV0VW1jQ0Z5ams
    2) Insert about a foot long 3.5mm inner diameter silicone hose (Verocious Motorsports)
    https://drive.google.com/open?id=0B-...U1TaWVkNmx0R0k
    3) Suck on hose until valve fully rotates
    https://drive.google.com/open?id=0B-...FNaX2pyV0NMQUE
    4) Crimp hose to hold vacuum and use a screw to plug. (Donor screws from your inner wheel wells fit perfectly)
    https://drive.google.com/open?id=0B-...Vl5dVdtZ09EWGs
    5) Plug the hose leading out from N-156 valve with another donor screw. (Not sure how important this is or if it will cause problems, but don't feel too comfortable with an open-ended hose)
    Results
    I test drove car for a couple of minutes around block and the car pulled like never before! Will test drive it more thoroughly (e.g. highways) and report back. I only have VCDS-lite but I'll run a scan to see if this set-up causes any codes. If no adverse effects (e.g. DTC's, misfires, gas consumption, overheating, etc.) from this "modification", then I would highly recommend doing it if your actuator and rotating valve aren't functioning.
    Aug 27 2013
    Philly
    1) Disconnect hose
    Results
    Good idea. I wonder if this will cause issues with the acuator. There's gotta be a reason why they have the unit rest in the other position when the car is off.
    I tried sucking on the line (phrasing) that heads to the vacuum canister and I couldn't get the unit to rotate. All lines are where they belong too.
    Which way does the vacuum pull from? The back of the manifold or the blue vacuum ball?
    Sent from my Nexus 6 using Tapatalk
    Jul 18 2014
    Los Angeles, CA
    So far so good. Car started smoothly and reliably with the locked low RPM setting. My understanding is that the rotating valve ("changeover mechanism" according to diagram) is by default on this low RPM setting. I think that it momentarily rotates to the high RPM on cold start but sets back to low; as seen in the video. It only kicks into high RPM setting at about 4200 RPM; which in daily driving you rarely get to.
    If artificially creating a vacuum (aka "sucking on the line") did not rotate the changeover mech, I wonder if the rubber bellows within the actuator aren't holding the vacuum? Can you rotate it by hand? If you said you just replaced it, I would video your actuator in action and see if it rotates at least when you hit 5k RPM. Maybe there's something wrong w/ my actuator which allowed me to do this temporary fix.
    As far as where and how vacuum pulls from, I'll be doing some research and trial and error to get this working properly. I'm really loving the regained torque on the lower end of RPM's. It's definitely noticeable to the point where it may get me a traffic violation because it just keeps pulling. But the trade off is felt on highway where I'm trying to accelerate.
    Will.bates94, how are things going?
    Dec 16 2014
    Fresno
    Tried revving my car to 5k RPMs and the Vacuum actuator didnt move from the rest position. Looks like mines broken too. Explains why I have no power at high rpm.
    Jul 18 2014
    Los Angeles, CA
    If it's stuck like mine was, you didn't have power at low RPM. Mine was stuck at what I'm informally referring to as High RPM setting because that's the position to which the valve rotates when it gets to ~4200RPM.
    If yours is stuck like mine, at your own risk, try locking it as I did and you'll be much happier if you do more street driving than HWY driving.
    Ran VCDS-lite and had no error codes after 45 min combined street/HWY driving.
    Jul 18 2014
    Los Angeles, CA
    Ooops...
    Aug 26 2005
    Quote Originally Posted by SJorge3442 View Post
    I suspect the reason the change over valve is default at the high RPM setting, and requires vacuum applied to the actuator to shift to the low RPM torque position, is because with low manifold vacuum, like when the throttle is open fully, will cause the change over valve to automatically shift to the high RPM position setting due to the low manifold vacuum at WOT. On the other hand with the throttle valve closed or mostly closed, manifold vacuum pressure is highest, and high vacuum at idle or low loads to shift the change over valve to low RPM torque position is coexisting and convenient. However, this also means the fail safe position of the change over valve is at the high speed power position.
    Jul 18 2014
    Los Angeles, CA
    In trying to fix the actuation of the changeover valve, I'm trying to understand how it works. Thanks for the info diagnosticator!
    I figure that since me "artificially creating a vacuum" rotated the changeover valve, those components function. Working my way from there, next step would be to check if the N-156 valve is functioning. Any tips on how to check this?
    Aug 12 2009
    Dirty Jerz
    I watched the video and I now want to go look at my car and see what it does. I've never really noticed an issue, but maybe there is one and I didn't even realize it.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    A vacuum switch is also in play. (#1 below)
    Image credit: SlickFix's 3.0 vacuum line DIY
    Jul 18 2014
    Los Angeles, CA
    Quote Originally Posted by imnuts View Post
    I wonder how many of us 3.0's are driving with a stuck actuator and missing out on the low RPM torque. If it is stuck, lock it as I did and you'll be very happy. I'm on my 2nd day driving it like this and I've had no issues; other than running out of road.
    Jul 18 2014
    Los Angeles, CA
    Quote Originally Posted by john_gonzo View Post
    Yes. ECS refers to it as the purge valve.
    https://www.ecstuning.com/b-pierburg...37906283c~pie/
    And there's #12 in diagram to check as well. Problem is that I don't know how to check if they're functioning properly. I believe that the combi valves are also involved in actuating the changeover valve w/i intake manifold. Does anyone know how to test these parts?
    Feb 03 2009
    Florida
    If purge valve (#1) switches at 4200 RPM...
    First method:
    Disconnect hoses from purge valve, connect a spare hose, start engine, blow through hose while a helper revs past 4200 RPM. Air should pass through the valve on one side of 4200 RPM but not the other.
    Second method:
    Disconnect hoses from purge valve, connect a vacuum tester to one port, pull a vacuum, start engine, rev through 4200 RPM while watching the gauge on vacuum tester (to see if it drops to zero).
    Jul 18 2014
    Los Angeles, CA
    First method:
    Second method:
    Thanks for the tip! To be clear, in the first method you disconnect lines from point A and B. Spare hose connects to ... A? Then air passes or gets sucked through B? I thought that air gets sucked at B because I artificially created a vacuum ("sucking the line") at B and that's what rotated the changeover valve.
    Jul 18 2014
    Los Angeles, CA
    First method:
    Second method:
    Forgot diagram, sorry. Thanks again for the tip!
    Feb 03 2009
    Florida
    A or B, suck or blow... any combo should be fine. The pressure differential you can create is much less than that produced by the engine.
    Jul 18 2014
    Los Angeles, CA
    Great! Thanks again. Will the same procedure apply in order to test the valve labeled #12?
    Feb 03 2009
    Florida
    Kind of. Parts #1 and #12 appear to be the same (Audi PN 037906283C), but I don't know when #12 changes position. That valve (#12) could probably be tested with engine off and then again when the engine is running. What I mean is:
    - With engine and key off, disconnect hoses from #12 and try to blow through it. (See note below)
    - Then reconnect the hoses, start engine, then slide one of the hoses off and listen/feel for vacuum.
    NOTE: It would help to know what the default unpowered position of these valves is supposed to be. If they close without power applied then you shouldn't be able to blow through it with the engine off.
    Jul 18 2014
    Los Angeles, CA
    Thanks again! Does your actuator function properly or is it stuck?
    Jul 18 2014
    Los Angeles, CA
    Bdw, after 2nd day of driving w/ valve locked at low RPM position, I rechecked vacuum lines from actuator. If you have installed JHM Intake Manifold spacers, chances are the line from the passenger side of actuator will make contact w/ this very hot pipe. It was starting to scald that line.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    To answer the question 'what direction should my broken actuator be clocked to ?"
    Put it in HIGH RPM POWER position. Alternatively you can even pull it out altogether.
    However, buy a replacement actuator as you pick up a bunch of low end torque when it's working properly.
    Jul 18 2014
    Los Angeles, CA
    Thanks for the tip! You're suggestion, combined w/ info from this video helped.
    https://youtu.be/Zj-_bAiPq9Y
    I manually tested #1 & #12 solenoid valves by disconnecting hose at the left side of T labeled #17 to check if there was suction. There was suction, so I kept holding my finger at the T while placing my thumb on #12 to "feel test" if it clicked over. You can feel it click over after about 5 seconds from placing finger at end of T. Since #1 and #12 are same part numbers, I swapped one for the other. Swapping them gives better access to feel test #1 because it'll be in the same place where #12 was. After doing this feel test a few times to confirm that I was indeed feeling the switch happen, I heard a pop in the actuator and noticed that it had rotated to low RPM! I reconnected hoses and proceeded to test functioning. It works!!! We'll see how it holds up in my drive tomorrow.
    Start:
    ~4500RPM:
    Turning off engine:
    I'm assuming that somehow in feel testing it and making the changeover valve move a number of times either by hand or artificial vacuum, the changeover valve loosened up enough for the solenoid valves to be effective...?
