Results 1 to 16 of 16
    Aug 20 2011
    Kenai, Alaska
    Replacing plugs every 800 miles
    Hey guys. Need some help. It seems after 800 or so miles after replacing my plugs, my car starts missing again. Rough idle, cutting out coasting to a stop, lack of power. I replace the plugs with the NGK bkr7e coppers. APR tune set on 93 octane. 3" exhaust, cold air, water/meth and the 2.0T coil pack conversion kit. This didn't start happening until about 5000 or so miles after I installed the conversion. Then....every 800-1000 miles. No vag com. And the AutoZone techs are clueless when hooking up the car....at least around here in Connecticut.
    Thanks for the help
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    I would check fuel trims via vag com or a diagnostic scanner with that capability. I would venture to say you may have a failed or failing sensor causing an improper fuel mixture
    Jul 04 2012
    Woodbridge, VA
    Have any pics of your plugs?
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Quote Originally Posted by akricer View Post
    the AutoZone techs
    Just wanted to let you know I lol'd really fucking hard at that.
    Are plugs black and sooty?
    2005 A4 Avant 1.8t QTM
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    Gap?
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    gap your plugs down .020-.025....I can never get them perfect but as long as the gap isn't larger than .025(with the autozone special silver coin gapper)....its the very smallest/beginning of that gap tool....problems should go away after that...
    2008 Ibis RS4....GETing tuned
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by axnjaksn View Post
    Lol. Based on what diagnosis? I've run .030 with no issues. Not saying it's right gap but simply stating it should not alone kill plugs.
    Gap is def a possibility, but my guess is more plug fouling. But we can only guess with what limited information we've been given.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    There is no need for that small a gap with the stock coils, let alone with the FSI conversion.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 24 2014
    Newport Beach, CA
    Well, I think the gap you run is somewhat dependent on the health of your ignition system for one. It varies for each car, especially on stock coils and ICMs. But since the OP has 2.0 coils, it could be fouling or maybe even an intermittent short in the coil adapter harnesses. Even if the gap is off, it shouldn't cause that dramatic of symptoms just because the gap might have slightly increased over the 800 miles or whatever.
    2024 M3 Comp xDrive
    Dec 14 2014
    PNW
    Fpr?
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    Post pictures of the plugs
    Sent from my SM-G900T using Tapatalk
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by cjt671 View Post
    Fpr?
    Have you checked your flux capacitor?
    Mar 07 2013
    LOLOLOLOL to all above comments...
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    Quote Originally Posted by LINDW4LL View Post
    OEM spec is between .016 - .024. Everyone just assumes that .028 is correct as plugs default to that gap.
    Sent from my SM-G930T using Tapatalk
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by mys4.org View Post
    Whaat? Some plugs I've measured over .035 out of the box. There's no way in hell OEM tolerances are that small.
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    I have an a6 with the 2.7t and I had done the TSI swap and ALWAYS had to replace the plugs every 1000 to 1500 miles no matter the gap (I did notice an improvement at .24 to .26 over .30). Fast forward a few months to swapping the engine for a 2.7 out of an 00 model. I never changed the plugs swapping the engine out, put the tune I had on the other ECU on the new one minus the dwell changes for the coil upgrade and got the car running... 15 k later the same plugs that were in the engine when I put it in are still running strong with 0 misfire issues! I don't know what caused the problem but I did wire my own connectors instead of using a prewired kit. OP did you use a conversion kit or do it yourself?
