Well, I just picked up an 05 A4 Avant with 144k miles a few weeks ago. I babied it until I was able to give it a complete tune up. It drove ok and felt like it was boosting ok. I just finished working on it. The work consisted of all new coolant hoses, forge tip, all new vac lines, new pcv, new ko3 turbo, turbosmart recirc diverter valve, spark plugs, and maybe a couple other things. Also installed a boost gauge.
All back together and it's running great. The old tip had a couple tears and the spark plugs were worn to a .04+ gap, so it's not surprising. My idle is great at -20 in/hg and -22 on decel. But my boost seems to be erratic. It was easily boosting to 20psi in higher gears. And this was at partial throttle. I haven't gotten on it yet because I don't know if it will stop at 20 or keep going. I've done a couple steady pulls in lower gears and the boost creeped up to 15 psi and let off the throttle. This is driving the same way it did before in regards to boost characteristics, it feels the exact same way. So I do not believe it's something I did.
Wondering what I could check? I do not have a cel or anything. Not sure if a bad N75 valve would trigger that or not. Does anyone know what stock wastegate pressure is? I was thinking of running the vac line from the compressor housing to the wastegate to rule out the N75.
Any input would be appreciated.
Gabe
