Results 1 to 35 of 35
    Senior Member Two Rings yossefay's Avatar
    Jan 11 2016
    Pittsburgh/Youngstown
    Getting Springs Installed
    Called my local trusted shop to get a quote on installing H&R OE Sport Springs. They quoted me at $500 for the job. I feel as if that is a bit ridiculous although they are including a balance afterwards. Without getting yelled at because I haven't searched around for it for hours, how much is the usual cost of this job? How hard would it be to do it myself? Thoughts are much appreciated.
    2018 B9 RS5 in Nardo Grey | 20' BBS CH-R's | Milltek Non-Resonated Catback | Carbon Imports CF Lip Spoiler | 35% Tint
    | 285's |
    Nardo RS5 IG
    Veteran Member Three Rings kobrian85's Avatar
    Oct 23 2012
    That's not a bad price. Balance, do you mean alignment? Not sure what your tires have to do with suspension installation...
    Figure $100/hr labor rate. That makes it a 5 hour job, which doesn't seem totally out of line.
    EDIT -- Oops, forgot something.... As for doing the install yourself, I can't really say on this car. I did coilovers on a Jetta Sportwagen two years ago, had the help from a couple of buddies, I think it took us 6-7 hours to do all four corners, and that included beer drinking and other shenanigans... You'll have to source a couple of tools, but it wasn't too bad. I replaced the coilovers with the stock suspension on my JSW before I sold it, and I did that myself and it took a me probably 8-9 hours.
    2019 RS5 \ Sonoma Green
    IG: kobrian85
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    My local shop did it for $350 with the alignment too. $500 not horrible though, little high, but not way out of line.
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    It's not a really difficult job to DIY. My friend and I did mine and the fronts took 45-60mins each side while the rears took 10mins. But we've done this before and knew what to do.
    30mins for an alignment after.
    Shops will charge flat rate and it usually takes about 4-5 hours.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    Jul 29 2016
    AB, Canada
    you do need special tools to compress the springs, but it's not too bad. 4-5 hours is the average time with alignment. Depending on what the shop rate is where you are. Dealerships are usually more expensive than after market shops are... you may save $50/hr by not going to the dealer. Myself personally, I always go through a dealer... I feel safer going through the dealer because they are usually more responsible if something goes wrong.
    Mar 21 2015
    Do it right the first time and do some Bilsteins shocks with the springs.
    https://www.ecstuning.com/Audi-B8_S4...its/ES3010022/
    Veteran Member Three Rings Teamnct4's Avatar
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    My local shop quoted me $450 to install springs and $180 for alignment.
    2015 S4 Premium Plus, Mythos Black, Black/Magma Red Interior, Black optics package, Aluminum Mirror Caps, Carbon Atlas Inlays, Airlift 3P, Airlift performance front and rear shocks, AWE touring with 102MM Tips, E-Codes, 20X9 HRE FF01.
    2020 RS3
    Senior Member Two Rings mjames's Avatar
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    I just paid $450 at independent shop and paid $189 at dealer for alignment. Need adjustable front control arms to get camber in spec, didn't realize that before I lowered. But I may not bother.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I paid $550 to install kw h.a.s with alignment.
    Sent from my SM-G925V using Audizine mobile app
    Jan 11 2016
    Would you like to help me pay for them? Joking aside, how good are they in the winter?
    Quote Originally Posted by mjames View Post
    What's wrong with your camber? Or is it that you want it to look a certain way?
    | 285's |
    Nardo RS5 IG
    Oct 23 2012
    Quote Originally Posted by yossefay View Post
    When you lower a vehicle, the camber will naturally change. Depending how low you go, you may fall out of spec. Most of the daily driven cars that are lowered are likely on the edge of being in spec, and in this case most people think it is fine to not hassle with getting adjustable control arms to bring it back into spec. My JSW was out of spec, but not to the point where it looked "off", nor did I notice any excessive tire wear.
    IG: kobrian85
    Mar 21 2015
    They have nothing to do with winter. Certain shocks are made for certain spring rates. Stock shocks are made for stock springs. With aftermarket springs you will ruin your stock shocks and the ride will become noticeably worse over time. Just replacing the springs is something someone will do only once because you will learn your lesson.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I agree, as many have learned this lesson, i.e. changing springs but retaining stock OEM shocks/struts. Here's a recent thread on this topic which should be informative.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Paid $300 for KW HAS install + $125 for alignment at local shop. This was the lowest quote out of 3-4 local shops.
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill
    Mar 21 2015
    Quote Originally Posted by LYKUNO View Post
    Bingo! Thanks
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    Mostly true, although I read the KW HAS springs are designed to work with stock shocks, aka if you have full ADS, the way to go. My ride is amazing, better than stock, and not bouncy or noisy one bit. So we shall see.
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    $500 is not unreasonable especially if it includes the alignment. Springs are not a terribly difficult job, but it is time consuming, each corner should take about an hour, maybe more if you get some stuck bolts.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Hmm I paid like 300$ CAD with alignment!!
    Murdered B8.5 S4
    Build Thread
    Senior Member Two Rings Seattle996's Avatar
    Apr 07 2009
    I lowered mine with a buddy.. took me about 8 hours. I was ready to kick the car off the jackstands... absolute nightmare if you have never done it before. My suggestion, pay the money. Cause once you are in the 4th hour of doing it on your own, you won't hesitate with the thought. :)
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by Seattle996 View Post
    My thoughts exactly! Ive done springs on prior cars a few times and it wasn't bad, but it was money well spent to pay this time around. There's no way I'm going to be able to do a good alignment myself, so really youre talking about maybe $300-$400 for the actual install and saving yourself many brain cells. I paid right around the $500 for install and alignment and it was a very reputable shop and it was cheaper than I had been quoted elsewhere.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Oct 31 2013
    Morris County, NJ
    Paid $450 for install with alignment. And get the Bilstein shocks while you are at it. Do it right the first time.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Aug 15 2015
    Cincinnati, Oh
    I couldn't agree more...Local shop quoted me at 900. I was shocked...all because I didn't buy the springs through them. So naturally..did it myself. It was a nightmare. After having done it know, I feel I could do it much quicker..but it was a very long job the first time. 500 including alignment seems worth it for my sanity.
    2013 Phantom Black Pearl S4 prem + DSG. APR stage 1, CTS intake, AWE touring exhaust. Rohana RF2's 20x10, H&R sports
    Established Member Two Rings na_v's Avatar
    Jan 27 2015
    i got it done for 250, but i didn't do it right with getting shocks, bilsteins on the way right now...
    Current : 2013 S5 Premium Plus | Glacier White | Magma Interior | DSG | ADS | Sport Diff | Carbon Atlas | B&O | Adaptive Lights
    AWE Track Exhaust | PUR 4OUR Forged Wheels | ECS Spacers | Carbon Imports Trunk Lip | Carbon Imports CF Mirrors | ECS Carbon Fiber Intake
    Past : 2014 Ibis White Audi A4 Progressiv | ECS Spacers | H&R Sport Springs | APR Stage 1 | RS Grille | US Millworks
    Mar 21 2015
    I just bought springs, spacers, shocks, and rear Akebonos today. Got a dealer visit soon so i'm going to have to wait until September for the install.
    Mar 10 2014
    Philly Area, PA
    Doesn't having ADS screw you on getting the Bilsteins though, unless you get the adapter to knock out the ADS system for $400 or so too?
    Mar 07 2010
    SW Florida
    Take that $500 buy some coilovers grab a friend and DIY.
    Jan 11 2016
    Quote Originally Posted by M3KILR View Post
    Coilovers are expensive though! I also do not want to mess anything up so I'd rather pay a shop to do it 100% right.
    What is my best bet as far as cost, quality, and ride height? I definitely don't want to ruin my ride quality but at the same time $1000+ Bilstein coil overs and new shocks aren't in the budget. If you were me, would you spend the money on wheels now or just get the suspension done and wait until next spring for wheels? I'm gonna be getting my exhaust done in the next week or so, and while I think function is my main priority right now I'm tired of the way the car sits on the stock peelers.
    Sent from my iPad using Audizine mobile app
    | 285's |
    Nardo RS5 IG
    Senior Member Three Rings AudiSTL's Avatar
    Sep 21 2013
    2011 S4
    st. louis
    i would buy the suspension now and then next summer buy wheels. reasons being you don't want the monster truck look and 2. car season is almost over... the stock wheels look awesome if lowered and stance is perfect imo
    AWE Quad Exhaust / Rotifom Ind 19x10 (old) / V12 245/35 tires / Solo Werks / ECS Carbon Luft Intake / Stoptech / Verde V99 19x9.5
    Enlaes CF decklid / EPL 1+ w DSG
    https://www.instagram.com/admirstl3/
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Jesus those are some good prices! A few years ago 3zero3 motorsports quoted 1k for spring install. I politely said no thank you
    Jan 11 2016
    Quote Originally Posted by AudiSTL View Post
    Yeah that's what I think I'll do. Maybe during the winter prices will drop too and it'll be a better time to buy. Thinking about getting the peelers powder coated in the mean time but not 100% sure.
    Quote Originally Posted by EHesh14 View Post
    Wow, $1k... That sir is a rip off.
    | 285's |
    Nardo RS5 IG
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    This x 1000
    $500 is not bad.
    Oct 23 2012
    EFF 3zero3, those guys can get bent. I've never heard anything positive about that shop.
    I've got a great indy shop in the Highlands that takes care of my motor/mechanical stuff. I'll probably go to Berg for springs when I get them done. Not sure I want to tackle the effort on the S4.
    IG: kobrian85
    Mar 07 2010
    SW Florida
    I really like my Vogtlands for under $1k. Coilovers, sways, drivetrain stabilizer and a Shortshifter are musts. I did the springs and shocks on my B5 and ride was crap compared to when I switched to coilovers.
    Jul 16 2010
    Colorado
    Quote Originally Posted by kobrian85 View Post
    Where do you take it? I've been taking mine to Hardey's Motorwerks in Parker and now I can't go anywhere else cause they are so good. They usually work on vw's, but they have a certified Audi tech
    Oct 23 2012
    I take mine to 5280 Motorsports (http://www.5280motorsportsdenver.com/), reasonably priced, super friendly, they've always taken care of me for my previous two cars that have excursively been taken there.
    I've heard great things about Hardey's too, but I'm on the north end of the Metro area, so Parker is no good for me.
    IG: kobrian85
