I managed to install a couple of treats recently. (also a couple parts from JHM - this was my second order from US imported to the EU)
- AP Racing front rotors (from UK)
- JHM rear rotors (from US)
- Ferodo DS2500 pads (from Germany)
- HEL Braided stainless steel brake lines (from Slovenia)
- Motul RBF600 brake fluid (from Slovenia)
- Hotchkis rear sway-bar (from US)
- 034 sway-bar spherical end-links (from US)
Cleaned up & re-greased the guide pins and brake pistons. I used dedicated ATE grease for this job (did a lot of research on which grease to use):
ATE Plastilube - for the guide pins
ATE Bremszylinderpaste (I love German!) - for brake pistons
For the sway bar end-link bolts I used Loctite 243 - which is some new updated formula, it's grease resistant and has better thermal capabilities than the old formulas.
AP racing managed to forget one bobbin clip, but they shipped the spare parts directly to my address the next day. Good customer care!
The sway bar was repainted in blue so it matches the braided brake lines.
Conclusion: The pads are amazing, the bite is far better than before on OEM rotors/pads. The brake pedal feel is a lot better. Also after bleeding the clutch it feels much better, more direct (I had occasional issues with a sticky clutch - now as it seems it's gone). The sway-bar makes a huge difference in countering body roll and pushing with the rear out of the corners!
