Results 1 to 10 of 10
    Jul 21 2015
    Boost gauge question.
    Project car is a stage 3 b5s4 and sadly I'm not going to daily drive it so I picked up a b6 as a daily. I'm going to throw a Daz tune on it and this is where I have a question. A couple years ago I had a b7a4 as a daily and I never put my boost gauge in. It's a podi steering column mount... Could I use the b7 assembly to put on my b6 as I will need to watch the stupid k03 so it doesn't blow. Thanks ahead in advance.
    Veteran Member Three Rings Mr.Avant's Avatar
    Jun 18 2012
    Edmonton
    Check the podi website and see if they are crossed across the platforms.
    Sent from my SM-G920W8 using Tapatalk
    03 A4 1.8TQ STD | Atlas Grey | S4 Alcantra Reacro's | S4 Bi-Xenon Lights
    Motoza Stg 1+ | TT 386cc injectors | Unitronic 3" Downpipe+HFC | Magnaflow 16601 | S5 coilpacks | SAI Delete
    JHM Short Throw Trio | BFI GS2 | Pioneer Navi | S-Line Wheel | Hardwoooood
    H&R Front Springs w/ ECS Coilover Sleeve | Statis Rear Coilovers | 3sdm 0.06 | 18x8.5 | et 27 Rear 32 Front
    Apr 07 2011
    I'm pretty sure they both use the same gauge just a slightly different setup on the boost line. Just follow the boost gauge write up on a4mods.com and you should be good to go.
    Jan 01 2012
    2004 A4 Avant
    CO
    i think he's questioning whether or not the steering column on the b6 and b7 are the same.
    OP, worst case if they are different, you could just buy a b6 gauge pod and sell of the b7 one. podi sells them separate.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    I thought he passed away.....
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Jul 21 2015
    thanks guys, it is the same steering column. so I get to use a part that's been setting around for years haha.
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Quote Originally Posted by PreciseD View Post
    He did indeed pass away earlier in the year. Quite suddenly too. 🙁
    Feb 05 2014
    Quote Originally Posted by MoparFreak69 View Post
    Yeah and no one mentions how or why....
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I heard it was pneumonia.
    2019 SQ5 Prestige
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Yes it will work
