Results 1 to 18 of 18
    Veteran Member Three Rings MyXbfS4's Avatar
    Jan 18 2015
    2000 B5 S4 Light Silver w/ Onyx (no sunroof), 2009 A4 Black
    Los Angeles, California
    power steering hose popped off?
    Hey there does anyone have a link or diy for where the hose for the power steering connects?
    Thanks in advance
    2002 Laser Red B5 S4 Sedan
    2011 Ibis White B8S5 4.2V8 Coupe
    2000 Silver B5S4 6mt Sedan(no sunroof)- SOLD
    2001.5 Silver B5S4 6mt Sedan stg3- RIP
    2000 Santorin B5S4 Tip Sedan- RIP
    Jul 04 2012
    Woodbridge, VA
    There are many places. Low and high side. Most high sides use banjo fittings so we can strike yhose from the list.
    If it popped off, where do you see it hanging? Or why do you think it's leaking?
    Jan 18 2015
    Quote Originally Posted by vavJETTAw36 View Post
    well its actually for a friend, he said there is about a foot of hose just hanging I believe towards the back of the motor and he doesn't know where to route it to connect it again. not sure if that makes sense but thats how he described it to me. I searched for some kind of diagram or something but couldnt find anything.
    Jul 04 2012
    Woodbridge, VA
    I don't believe there are any low pressure hoses near the back. Most likely not power steering. Get him to send you a pic.
    Jan 18 2015
    ok I will, thank you for helping.
    I'll post it as soon as I get it.
    thanks
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    Quote Originally Posted by MybfS4 View Post
    thanks
    The power steering hose at the back of the engine is metal but after 6 or 8 inches it turns to rubber and heads to the steering rack, if it came loose its most likely he'll need a replacement cause its a high pressure
    Jan 18 2015
    Quote Originally Posted by 2000s4_m View Post
    I believe this is what happened, so after he gets a replacement how does it go back on? thats what he cant figure out. Is there a link for a DIY anywhere? I searched but couldn't find anything.
    or is it really simple and we're just noobs...lol
    thanks for the help, I appreciate it
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Nope, that hose goes to the rack and it's a shit job unless the engine is out. Getting the new hose in there, especially while contorting your hand to keep the banjo bolt and new crush washers in place while screwing it all together, sucks. Replace the smaller hose that connects to the rack while you're doing everything.
    2005 A4 Avant 1.8t QTM
    Sep 05 2012
    Mcallen, tx
    ^^ that!
    I'll get a picture on a car i have here for parts so you can get an idea of what he just explained
    Jan 18 2015
    Quote Originally Posted by themadscientist View Post
    Yikes, that sucks! especially since I'm pretty sure he recently pulled the motor for something unrelated and already put it back in. Sucks to be him lol.....
    jk *crossing fingers* I hope I didnt jinx my car now
    Jan 18 2015
    ^^ that!
    thats awesome of you, thanks.
    Sep 05 2012
    Mcallen, tx
    This is the hose in question, see how it turns to rubber as it hides away behind the aluminum cover and once inside it turns to steel again as it bolts to the steering rack
    Jan 18 2015
    cool thanks, I'll send these pics to him and make sure thats in fact the one he's talking about. I'm pretty sure it is because I remember him saying something about only part of it was rubber. thanks again
    Jan 18 2015
    so I showed him the pics. this is what he texted back
    "It goes from power steering across motor to res.
    Across eng. in steel tube somewhere it connects to rubber with factory hose clamp"
    Do you know what hose that is? I guess he needs to know where that hose goes. sorry for the confusion.
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Have him send you a photo. He seems to be describing one of the supply hoses, but that contradicts the hose hanging from the rear of the engine.
    Sep 05 2012
    Mcallen, tx
    Does he mean this one? (Pointed by screwdriver) thats on the driver side of motor and going to reservoir
    Jan 18 2015
    Quote Originally Posted by slowSfaux View Post
    I told him to send one, will post as soon as I get it. thanks
    I just asked will let you know, thank you
    I really appreciate the help with not alot of info to go on, you guys are awesome for being so patient, seriously its great to be part of this community.
    Jan 18 2015
    I guess its the skinnier one on the resevior
