Results 1 to 11 of 11
    Oct 27 2015
    NorCal
    Rear Valance bracket issue
    About three years ago, I had someone hit me from behind and dent the bumper. I had it replaced via my insurance. Fast forward to now, I am washing the car this past weekend and while cleaning the rear valance, I hear a rattle sound. I crawl underneath the car and I see the bracket. The top screw that is attached into the metal bumper reinforcement bar is very loose. It doesn't look like a screw but a rivet and the middle seems to be stripped... Or maybe it is a screw that is stripped. Anyway, is the screw in the bottom suppose to be the same as the one in the top? I am thinking the body shop did a shitty job attaching the top screw. I only see fixing this issue by removing the rear bumper and getting some self tapping screws and reattach but no wanting to do that. There is not much room there so a regular drill will not fit. Maybe use a right angle drill and a self tapping screw? Any other ideas?
    Veteran Member Four Rings Audi_509's Avatar
    May 20 2010
    2008 A4-sold. 2019 A5-sold,: '23 S5
    WA
    I had the same issue. I used rubber bands but they failed after a few months. I ended up punching out the rivet and used a self tapping screws. It's a tight fit but it can be done without taking out the bumper. Here are few links with additional information and options.
    http://www.audizine.com/forum/showth...valance-rattle
    http://www.audizine.com/forum/showth...ap-replacement
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    Ya it's a rivet not a screw, don't know why they did that because those plastic things that hold the bumper cover break all the time and then it sucks to repair them.
    Feb 15 2016
    Cambridge,Ontario
    ..unless you got hit again and didnt realize it .. looks like that rivet has been stressed.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 24 2004
    Minneapolis
    It is a rivet. Got tired of hearing the rattle every d--n time I closed my trunk so I removed the cover and the aluminum bumper and did this. The plastic was broken on mine so I cut it out and put a piece of scrap aluminum angle in there. Has been fine for over a year now.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jul 18 2015
    Here's what I did to replace mine lol
    Feb 15 2016
    Cambridge,Ontario
    That's some elegant work andy. You missed hour calling as a dental surgeon....not!!!
    1976 Yamaha XS 360
    Jul 18 2015
    Hahaha, I was so pissed when I ordered the plastic parts and then went under there and realized they're not screwed in with a real screw. I'm just like, hell I'll make these damn things fit! And now they're quick release, just slide them right out!
    Oct 27 2015
    NorCal
    Thanks for all the postings. I see the engineer that designed this part on our cars should have been reprimanded for their suggestion. Sounds not too bad to fix. Thanks everyone.
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    I had 2 new braket, and I ended up with zip tie. did the job
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by A4manic View Post
    When I see a really bad design like this, I always imagine some Engineering Manager throwing a simple little project at some kid straight out of college and telling him, "If you spend more than 2 hours on this your not cut out for this world. It's not a new motor, it's a dumb little bracket."
