Originally Posted by
Sean@APR
I'm not entirely sure what the OP means by "found out there is a issue". I think I saw your ticket this morning and replied asking what you meant by that.
We DO have a ticket in for this, it came in a couple days ago and we've been trying to get somebody to make us a video of exactly what's happening. Adjusting shift points is straight forward, we just need to know exactly what the scenario is in order to make the right adjustment.
If your car is experiencing this, please grab a quick video with your phone of the dash. Also, please explain in the video how much throttle you're giving the car.
In short, to adjust shift points we need to know:
1. RPM before the shift
2. Pedal input
3. Gear before the shift
4. Expected behavior
A video is the best way to cover all of the first 3.
Sean,
I apologize for the confusion. This is pertaining to my vehicle with the APR TCU tune. MY 16 S6. I hope this clarifies.
Tunes:
ECU - v1.1 93 Octane Stage I
TCU - DSG S6 Tune
Issues:
The vehicle will upshift to a high gear at 5100-5500 in 2nd - 7th gear and will up shift at 5500 in 1st to 2nd gear. This will occur independent of drive mode D, S, or M, occurs in every mode. The car will not go above 5500 rpm in any gear under any circumstance. This is independent of throttle input position 0-100% it will occur at the entire spectrum of throttle input. It can occur at WOT or just gently accelerating the car however once you reach 5200-5400 rpm it will upshift ALWAYS to the next gear.
Conditions:
RPM Range: 5200-5400 rpm gears 1st thru 7th
Throttle Position: 0%-100% - condition occurs at every position
Gear - Occurs In every gear
Drive Mode - Occurs in every Drive Mode
Condition Set in TCU that are user definable.
Auto Upshift - On
Auto Downshift - On
Launch RPM - 3000, 4000, 5000 rpm
I had Jeff from HS tuning record video. He has all of the copies and should have forwarded them to you as well. We tried to describe best we could on video. However, also captured it on tape multiple times. It is impossible to go that high on rpm in the higher gears due to traffic or legal restrictions.
- - - Updated - - -
Sean@APR
The first we've heard about this came just a couple days ago. All we need is to know exactly what is happening that is unusual and we'll update the shift maps and roll a release. Very quick and easy process.
I posted on the forums since this is the first I heard of this issue regarding the TCU and wanted to see if there was other people or isolated to my vehicle.
