    Senior Member Three Rings TheRedGlacier's Avatar
    Oct 31 2015
    1994 Firebird Trans Am GT 6MT
    New York
    Front caliper guide pin stripped?
    I have been having some issues with my front left brake for the past couple of weeks (2001 quattro) and I went to remove the brake pads to inspect them, top caliper guide pin came out, however the bottom pin appears to be just spinning no matter which direction I turn it. Does anybody have any suggestions? I would assume it is stripped. Can I pull the caliper carrier off? I installed them last, and I made sure they were not crooked, nor did I believe to have overtightened them.
    Nov 02 2008
    A mess.
    Grapevine,TX.
    Are you sure the pin is spinning and it's not just a stripped allen head on the bolt?
    Oct 31 2015
    New York
    I'm positive the pin is spinning you can see it poking out of the other side. The whole pin spins.
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Happened to me on a 98 Beetle. Sucked. Ended up swapping in a different spindle
    Sent from my LG-H815 using Tapatalk
    Nov 02 2008
    A mess.
    Grapevine,TX.
    You could heli-coil it, but I would go with a replacement spindle too.
