Results 1 to 2 of 2
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    No fault codes, but
    The car had a hiccup last night so I decide to just check for any codes, there were none so I checked the readiness. I got this. Suggestions? Thanks in advance.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Typically that just means there is not enough miles on the car since a battery change or some other reset.... Nothing to be to concerned about just yet (Especially since no hard codes).
    IIRC - Some tests require a certain minimum mileage or they average some sensor values and don't enough data points to correctly calculate the average...
    Simple answer drive the car for ~100 miles to get over the hump - also some test require multiple on/off key events or drive cycles - so you may need to drive it around town and turn the car off a few times within that mileage.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
