Results 1 to 13 of 13
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    Our clear coat is no joke!
    So finally set out on a paint correction on my '13 A7 after owning for a month. I gotta say this was the most stubborn car I've ever dealt with. I've been doing amateur paint correction for about 4 years now and have always gotten great results with out really having to fight a vehicle.
    A miata I did last year
    B5 S4
    There's been plenty of others, but my A7 kicked my ass. I started with a full iron X as there was a lot of rail dust
    After that I did a "clay bar", nano skin auto scrub, then I started the correction. I first started with orange pad wolfgang total swirl 3.0....that wasn't enough. Switched to chemical guys V36 with orange pad, still not enough. Switched to a yellow pad that seemed to make it better, moved on the Chem guys V38 with a green pad cleaned it up but there's still some very slight marks. Tips/ideas on how to get rid of them for good?
    I like how the badge cleaned up
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    Apart from changing compound/polish, you certainly did what I would have done. I use Menzerna FG400 for compound and Sonax Nano for polish and have had great results with those two.
    What buffer are you using? I had an older Porter Cable and it got "tired." I bought a new buffer and instantly life got easier.
    Jun 03 2016
    Omaha NE
    Torq 22D
    Jul 26 2016
    South Fla
    I've never heard of rail dust and had to look it up. Funny enough my new to me '12 has it on the back bumper/rear lid area. Discovered it on the first wash which is when you really get intimate with the exterior of a used car. I've never had this on any car ive owned. Where on you car was it located. Im wondering if the car itself is producing this.
    Boris... why always Boris? You come at the king you best not miss. I dont know nobody named Barksdale B. My name is my name! You Mcnulty, are a gaping as#$%^le. On a sunday morning , on a sunday morning.../// And now the coffee maker sucks, howdya like them apples? 'The F%$K does that have to do with cold medicine. Friend of a friend, not a friend of ours. Either you take it into your heart that I did not do this, or this is as far as we go.
    Jun 03 2016
    Omaha NE
    Most cars have it, just more visible on white. Its from when the cars are transported on the trains, the wheels of the train kick it up.
    http://www.carwash.com/rail-dust-and-its-removal/
    Jul 26 2016
    South Fla
    Quote Originally Posted by 2wookies View Post
    From what I understand the term rail dust originates from the train scenario but is still used to describe tiny metal particles embedded in the paint. Plus with our cars they are well protected during transport when new, and mine has lived in my county all its life.
    Established Member Two Rings TD_05's Avatar
    Dec 19 2013
    2016 Audi S6 2005 BMW M3 1994 Nissan King Cab
    Midwest
    I feel your pain. I came from a 2008 brilliant black S4. It is the worst paint that I have ever worked with. Others had suggested a torq22d, which brings up a good question, what DA machine are you using? What diameter pads?
    With my Audi I only used the Griot's DA. Originally with large diamter pads, but switched to 5.25 inch and found that they offered more cut.
    Other suggestions: Try a microfiber orange pad
    Not sure how aggressive the compounds you were using from CG, I am not familiar with their polishes / compounds. I usually don't use meguiars, but read that their m105 is pretty effective against hard clearcoats like Audi. Or try Sonax Cutmax, I've never used that
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Afaik 'rail dust' is actually a mix of metal scraped parts of the electric power wire and it's guider and maybe hot metal wheel particals when breaking.
    Cars that are parked near railroads often suffer A LOT by this and hard to get ride of.
    Don't quote me, but working in a harbor where a lot european branded cars enter by train for export to other parts of europe and USA for example.
    Not so sure about Audi (as that is other dock) but hardly any cars are covered in plastic at arrival by trail and most trains are of the non closed type (the high-end mercedes for example also don't have covers, maybach included). Most cars get transported by train, only a small amount by truck, let alone in closed trailer trucks (lambo, masserati,...).
    If not mistaken, only RS and R models arrive fully wrapped and in cover at port.
    End information :p
    Speaking of clear coat, imho it is very poor :s. My cardetailer had a hard time getting it decent.
    Previous owner had the 'boot dog wrap', when they tried to peel it off, it pulled of the clear coat....
    Same for the stone protection wrap on the fender between door and wheel, pulled the clear coat.....
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Jun 03 2016
    Omaha NE
    That's what I'm saying it's so hard to get scratches and stuff out because it's so hard.
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Torq 22D
    Make the jump to a rotary... I did last year and it is epic the difference it makes. It gets less scary after you use it for a few passes.
    Feb 21 2012
    Aurora, CO
    I just got a 12 A7 and the swirls were hopeless. My porter DA would have been worthless. Makita rotary and a lake country yellow with FG400 takes down everything nicely that I've come across so far.
    Jun 03 2016
    Omaha NE
    Sooo scary!!!!
    Feb 21 2012
    Aurora, CO
    Sooo scary!!!!
    It's easy!!
