Results 1 to 18 of 18
    Veteran Member Three Rings JayCar's Avatar
    Dec 13 2015
    2023 Tesla Model Y Performance, 2022 MINI Cooper S Countryman, Specialized Tarmac SL4 Sport :-)
    Houston, TX
    3.0 Coolant Temp
    Did a quick search in the Q5 without results. Does anyone know what the normal coolant temp is 3.0 (SQ5)? I'm smelling something of a "hot temperature" smell coming through the AC vents occasionally. According to my P3 gauge, the coolant temp is 203°. Granted it's 98° here in Houston right now, but I haven't really paid attention to it until now to know if it's above normal.
    If it were an LS motor, I'd know 195° is spot on. :-)
    Thanks for the input!
    2014 SQ5/Monsoon Gray
    Go: APR Stage 2+ w/ SC pulley, Airbox mod w/ aFe hi-flow filter
    Ride: H&R Street Performance Coils, RS6 reps in Gunmetal 21x9.5 w/ Michelin PSS 285/35/21
    Look: P3 vent gauge, HID fogs, E-code heads and tails, Many VCDS mods
    Rebuild Thread
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Check the top of your coolant reservoir. The line to my reservoir wasn't snapped all the way on from the dealer and I got that smell. It was an easy fix.
    Dec 13 2015
    Houston, TX
    3.0 Coolant Temp
    I'll check it. Ive had front clip off a few times. Maybe it's worked itself loose. I checked the coolant level today, and it's half way between min and max.
    Rebuild Thread
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    Also check if there is any residual of coolant spray, front driver side of the engine. Water pumps are known issues on the 3.0T's and can leak on the belt causing it to spatter..
    Dec 13 2015
    Houston, TX
    3.0 Coolant Temp
    I looked for coolant last night, but will check again today.
    Anyone know the stock running cooling temp? :-)
    Rebuild Thread
    Mar 28 2013
    Chicago
    If it's warmed up, A/C on, and 98F outside, I'm honestly surprised it's not higher than 203. Most modern engines will push into the 220s pretty regularly with any kind of load. With a 15/16psi pressurized system, boiling point isn't reached until well into the 250-60+ range ...not that those temps are going to be doing good things for power production and timing pull-back... Hope this helps
    2013 Q5 3.0T Phantom/Black
    APR Stage2 | APR CPS | 034 Inlet Hose | ECS 12.5/20mm | 255/50-19 DWS06 | 034 Inserts | P3 | ...
    2020 MB GLC63, Black,
    2019 BMW M2 Competition, Black, 6MT (sold)
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by JayCar View Post
    My Q5 3.0 P3 has always been around 203-204, the other day in Florida sitting in traffic dash temp was 102 with AC on P3 hit 210 coolant but once I started moving again it went back down to 203, seems normal.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Dec 13 2015
    Houston, TX
    Ok good deal. Just wasn't sure what normal op temp was.
    Rebuild Thread
    Senior Member Three Rings rgvsq5's Avatar
    Feb 03 2015
    Texas
    I live in South Texas where it's 100+ daily and my temps hover around 203 according to P3 gauge.
    SQ5 | APR Stage 2+ : APR CPS v2 : AWE : Bilstein : H&R : ECS Tuning : 034Motorsport : P3Cars : Adam's Rotors : E-Code : XPEL
    Dec 13 2015
    Houston, TX
    Quote Originally Posted by rgvsq5 View Post
    Me too... "Hot as Hell Houston" :-)
    Rebuild Thread
    Apr 26 2014
    DFW
    It's not exactly delightful in DFW either.
    Hey, are you guys doing the fun run on the 13th? It's only $10. We're meeting at Cavender Audi in San Antonio.
    Here's the link to register: http://www.audiclublonestar.org/even...up-and-fun-run
    Hope to see you bumpwads there!
    Dec 13 2015
    Houston, TX
    Quote Originally Posted by SQive View Post
    Maybe ;-)
    Rebuild Thread
    Jun 27 2011
    Most modern Audi engines should be in the 80-90°C range. 200 seems spot on.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    my p3 usually reads around 200-205
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Dec 13 2015
    Houston, TX
    Ok. Good deal. I'm "cool" then at 203° :-)
    Rebuild Thread
    Apr 26 2014
    DFW
    Maybe ;-)
    Nah, see. . .you have to go because there's something about your SQ that I want to check out, although for the life of me, I can't remember what it is.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Dec 13 2015
    Houston, TX
    That looks familiar. :-) ... Minus the Escort smart cord.
    Rebuild Thread
