Results 1 to 8 of 8
    May 15 2014
    Whittier, CA
    Timing belt help please
    So I did the timing belt job this past weekend (using Phils DIY) and got all my marks lined up and the car runs great but the problem now is that the belt doesn't want to center on the pulleys?! It is making a bit of a squeel and one side of the belt is fraying. Did I do something wrong and is there an easy fix without removing the whole front end again?
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I can't tell you what happened, but I can say that if the belt is starting to fray you better replace it again. I wouldn't trust that at all.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Mar 24 2013
    Oakdale, CT
    I had this exact thing happen to me. The cause ended up being the tensioner stud. Somehow I managed to bend it slightly while I had the head off. After installing a new stud, all was good. I would replace all bolts and studs associated with the tensioner and idler bearings.
    -Adam
    Oct 31 2014
    NH
    Did you keep the same belt? Seems sketchy.
    Mar 24 2013
    Oakdale, CT
    I did keep the belt, but I noticed it wasn't centered before I put everything back together. I always rotate the crank by hand a few times to check.
    -Adam
    Oct 24 2015
    Perth, WA
    Def new belt.
    My respray thread
    Jul 27 2016
    Earth
    Crank the engine by hand a few times and see what happens. If the belt is centered, then while the upper timing cover is off, start it and let it run, notice how the belt moves, does it sway etc? record it if u want and view in slow motion, that will give u an idea. Only things I can think that could mess the belt is, as mentioned before a bent bolt for one of the tensioners, or possibly something being stuck on the inside of the belt, could be debris? or worn bearings on tensioners. Did you replace the tensioners?
    May 15 2014
    Whittier, CA
    Thanks for the responses/help guys. Hopefully I can get to the car tomorrow and try your suggestions.
    Quote Originally Posted by veeray View Post
    Yes, I replaced the belt, water pump, belt tensioner and the two idler wheels.
