Results 1 to 14 of 14
    Jul 28 2016
    Calgary
    Need Help With Non Stop Shaking 2011 Audi A4!!:(
    Hi everybody!
    Still having issues with my 2011 Audi A4, there has been non stop shaking and misfire of the cylinders. Codes read: P0300 with the 304,302,303, and 301. Brand new spark plugs and ignition coils have been put in and still no help. Any suggestions what to do next??
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    How many miles on the car and has the timing chain tensioner been updated/changed?
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Junior Member Two Rings
    May 18 2015
    westchester
    Check your fuel pressure
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Are any of the MIL lit on the gauge face? Any error codes?
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Jul 28 2016
    Calgary
    Quote Originally Posted by mecg View Post
    Car is running at 120,000 KMS at the moment, and not that I'm aware of. I was considering changing the PCV, but the timing chain tensioner was definitely on the back of my mind as well. Just don't want to put in the $$ till I'm certain..
    Jul 28 2016
    Calgary
    Quote Originally Posted by plat View Post
    Yes, the CEL is on and the codes read with scanner are as follow : P0300 with the 304,302,303, and 301
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by Dennytran View Post
    With misfires in all 4 cylinders even after changing the plugs and coils, only two things remain, check the fuel pressure (perhaps change your fuel filter) like adlerc35 said and do a compression test. Any chance you just filled up and maybe got a bad tank of fuel?
    Senior Member Two Rings rdenivo's Avatar
    Jan 05 2016
    2011 VW Tiguan
    You may want to look into this.
    http://www.audizine.com/forum/showth...-Notice-letter
    I had a similar situation with my VW Tiguan, replaced plugs and coils to no avail. Wasn't the fuel pumps either. It turned out to be a bad fuel injector, but I never got a letter from VW saying this was an issue. I submitted the bill to VW and they reimbursed me within 6 weeks.
    Jul 28 2016
    Calgary
    Some extra information that might be of relevance, oil has been consistently found on my spark plugs and ignition coils. I've had the problem before where the car started shaking, and after cleaning out the cylinders and changing both the spark plugs and ignition coils the shaking stopped. However the CEL remained on for quite along time. I noticed a similar problem where smoke was started to come out of my exhaust again, so assuming it was the same issue, I replaced the spark plugs and after about a day thats when my car started shaking again. But now it hasn't stopped. AHHH
    Jul 28 2016
    Calgary
    Quote Originally Posted by rdenivo View Post
    Yeah I suspected it could be the fuel injectors, I do currently have an extended warranty to cover that. However, they are making me pay for a $160 diagnostics test before allowing anything to be done. I will be bringing it into the dealership in the next couple days to see what they have to say..
    Veteran Member Three Rings Dannaye's Avatar
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    My car was shaking so badly, changed out my motor and transmission mounts and its all good now.
    Established Member Two Rings TJet1.8's Avatar
    Jun 14 2015
    2016 Q5 3.0T
    Ontario, Canada
    For the A4 B8's (2009 - 2012), I generally do the following in this order until the issue is resolved:
    1.) New Plugs
    2.) New Coilpacks
    3.) Run fuel injector cleaner with a full tank of 94 gas (twice)
    4.) New MAF
    I did this on my 2011 A4 (132000Km) and my wifes 2012 A4 (72000Km) and it generally fixed all misfire/shaking issues.
    The fact that you have oil residue on/around the plugs and coilpacks indicates a more serious problem.
    Unfortunately I have not encountered such problems and cannot offer a concrete resolution.
    Sounds like an injector problem, fueling issue.
    Do you have the Oil Consumption issue with your A4?
    If it was me, I'd take it to the stealership or a reputable German car Technician.
    • 2017 A4 2.0T - Custom Stg2 ECU & Stg1 TCU Tune (409HP/395TQ - No Meth) from garageautosports.com (thanks Bill!!), CTS CAI + TIP, CTS Intercooler, CTS Charge Pipes, GFB DV+, CTS 3" Test Pipe, CTS 3" Catback, APR Coilpacks, RS3 Plugs, 034Motorsports Trans Mount Insert, Snow Stg2 Water/Meth., Bilstein B8 Performance, H&R Sport.
      2016 Q5 3.0T - Custom Stg1+ Tune (455HP/395TQ) from garageautosports.com (thanks Bill!!!), CTS Supercharger Pulley, 034 Intake Pipe, aFe Dry Filter.
    Senior Member Two Rings NoUDont's Avatar
    May 16 2007
    South Florida
    This happened in my '09 and it was the Intake manifold. Check rubber piece in the back to see if it is popped out. Push back in vibration goes away. Accelerate past 3000 rpm, it will pop back out.
    Easy to check
    Feb 24 2013
    CA
    Its your pcv valve. Almost 100% sure of it with those codes. You can do a quick check and pop of the cap on the pcv valve and check the diaphram.
