Results 1 to 8 of 8
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    2013 A4 Rear Brake Light Installation (rear window)
    I'm not sure what I'm missing, but conceptually, it is very intuitive....but why is it not snapping in?
    Also, the dealer said one of the clips were broken, but I don't know what clips they are talking about since I compared the new one to the "broke" one and they look the same....
    I know the headliner needs to come down a bit, but can you get it to snap it and then pull the headliner over it or does it need that extra room to snap in?
    What a PITA!
    1997 BMW M3
    CES Stage IV (651rwhp/615rwtq @ 24 psi)
    2020 S6
    Premium Plus, Black optic, performance exhaust
    2013 Audi A4 (sold)
    Prestige package, S-Line, 6-speed |IE Stage 2 | IE Performance Downpipe | S4 exhaust swap | ECS Luft-Technik intake | ECS Luft-Technik FMIC | RS4 grille | ECS SSK | ECS Trans/Diff Inserts |
    Jan 13 2014
    nyc
    Quote Originally Posted by BMWManiac View Post
    What a PITA!
    lol having this same fucking issue.....took it off. kinda makes me feel retarded that i cant snap it in
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    I'm about to head down this path as well, due to my third brake light being intermittently out. I have swapped headliners, but never removed my third brake light; the links below may help.
    http://www.diyaudi.com/Home/Entries/...d_Install.html
    http://www.audizine.com/forum/showth...-Light-Problem
    https://www.youtube.com/watch?v=vFYQWeh5lNg
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jan 19 2016
    Orlando, FL
    Like I said, the concept is really easy and you would think it would just slide back in. I think I finally managed to get it to snap in. I'll see if it falls down any more, but the weird thing is, I still don't know what clips the dealership was saying were broken....I bet they were just having a hell of a time getting it to snap back in and assumed it was broke!
    1997 BMW M3
    2020 S6
    2013 Audi A4 (sold)
    Jan 13 2014
    nyc
    i thought i got it in too...but then the shit came out on one of the corners and was lopsided. i removed it completely nd havent bothered with it again..
    i bet you they told you something broke so they can charge you an additional 200000000.00 usd in parts and labor.
    Oct 23 2014
    _
    Aren't the clips for the light on the window itself? It doesn't clip into or under the headliner, but I think the headliner rests snugly around the light, so you will need to fit it under the headliner at some point. The only other clips are on the light itself, so if those look the same as the old one, I would guess its the clips on the window.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jan 19 2016
    Orlando, FL
    Quote Originally Posted by bakedziti View Post
    Then both "clips" are present....I wonder if the two metal tabs inside of the slots on the light are supposed to press down and then as they pass the edge of the two rails, they "snap" into place catching them and then the headliner just goes over it? I'll keep trying, but right now, they are not both snapped in, that is for sure
    1997 BMW M3
    2020 S6
    2013 Audi A4 (sold)
    Jan 19 2016
    Orlando, FL
    Ok, I think I got it figured out....the headliner was the problem the whole time. It is just too thick/sturdy to snap the light in place and then place the headliner over the lamp. So, I pulldown the headliner gently, while at the same time sliding the light back onto it....which allowed the light to have no problem sliding as far back as possible. Put the headliner back in place and done! Should the light fall back down, I'll keep the thread posted
    1997 BMW M3
    2020 S6
    2013 Audi A4 (sold)
