Results 1 to 15 of 15
    Registered Member One Ring pentaquine's Avatar
    Aug 02 2016
    Slaver's Bay
    Question Manual transmission not smooth and oil change?
    Hi I'm new here and I have a 2013 S4 6MT for about 6 months. Needless to say the car is awesome and so is the gearbox. However, sometimes I notice the shifting is not very smooth after driving for a while I live in area which is notorious for bad traffic , so I have to do a lot of stop and go and shifting, and after half hour or so, when I shift gears it just feels like the stick (yes the stick itself) is rubbing against something, like some metal. It just feels like something is not lubricated well.
    And when I took my car to dealership for 35k miles maintenance, I asked about this issue and if they're gonna change the transmission fluid. The guy told me this is a manual gearbox so there's no transmission fluid to be changed. I mean manual transmission should still have some sort of fluid right?
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    There is fluid. They probably meant that Audi considers is "lifetime" fluid.
    I've changed fluid at my 35k service.
    No MT car likes stop and go traffic. I'm sure your clutch is not happy either which is probably the main issue.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    lubricate the ball at the bottom of the shift lever.
    May 31 2014
    Alabama
    Quote Originally Posted by S4'ed View Post
    How do you access said ball?
    (Hey, watch what you're thinking!)
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Synchros have been known to not work smoothly. Not a common problem
    Aug 25 2013
    florida
    Quote Originally Posted by MrFunk View Post
    did you have it serviced or diy? if serviced what was the ballpark charge?
    2014 sfeux p+ 6mt bo nav w/o sd
    Jun 28 2012
    North NJ
    FWIW I found the stock shift action to absurdly poor. Too much play and comically long throws. Driving was much smoother and far more enjoyable after I installed my short throw shifter.
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Nov 12 2015
    Here
    ^ FWIW I find the stock B8 shifter to be "absurdly" good. I'd say it is a "comically" big improvement over the B7. I actually like the action better than my B7 with a JHM short shift kit.
    Mein ist grau
    Aug 02 2016
    Slaver's Bay
    Why do you change it if it's "lifetime"? And how much did it cost? What MTF did you use?
    Jan 24 2014
    United States
    stock shifter is awful. its made of plastic. I installed the jhm shifter and im quite happy with it
    Jun 15 2010
    Chicago
    I changed mine just for fun at 87K miles. It was 3 liters and that fluid was also shared with the front differential. Simple drain and refill. There's a DIY on here somewhere. I stuck with OEM fluid which was actually pretty expensive but I read others like Redline fluid wasn't as smooth in cold weather.
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Sep 24 2014
    Central NJ
    No fluid is "lifetime". Change the oil in the manual trans (and Diff) every 50,000 miles. Change the DSG fluid & filter every 30,000 miles (and the separate DSG front diff gear oil every 50,000)
    Apr 04 2012
    MSP
    Quote Originally Posted by pentaquine View Post
    I changed it (as many others have as well) because I don't believe in any fluid being "lifetime". What came out was very dirty.
    I used https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Quote Originally Posted by Oloung1 View Post
    I had it done at my 35k service at the dealership since they'd have it up already.
    I think they charged me 1 hour labor - which is high but it's hard to get anything done for less. It's quite easy to DIY.
    Here's a DIY - http://www.audizine.com/forum/showth...n-Fluid-Change
    I also did my rear differential fluid.
    Aug 02 2016
    Slaver's Bay
    Thank you for the link! I wonder if there's a way to save the post on this forum...
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Just subscribe to this thread (use the Thread Tools link at the top). Then, it'll always appear in your list of subscribed threads.
