Results 1 to 21 of 21
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    Removing resonator on stock DP vs getting after market non res DP
    So, another member pointed this out - instead of getting an after market non res DP, he removed the stock dp resonator which only cost him 1/4 of getting after market non res DP.
    Anyone else here have the same experience? on removing your stock resonator? As much as I'm patiently wait for used ones on the after market non res DP but seems people are holding on theirs.
    I'm kind of ready to shell out for new one but if I can have better deal, why not? Any advantage/disadvantage on removing your stock resonator? sound wise would there be a lot of difference?
    - iKe -
    2011 S5
    2011 A4 Avant
    Veteran Member Three Rings rooneyy's Avatar
    Jan 08 2016
    Toyota 4Runner
    Quote Originally Posted by Avantmaniac View Post
    I'd like to know this as well. I have AWE Touring on my B8 and I would love a little more sound to it.
    Active Member Two Rings aliensporez's Avatar
    May 31 2016
    Houston, Texas
    I haven't done this on my S5 yet, but did it on my XFR. Total cost was under $100. There really is no reason to go aftermarket simply to remove a resonator, I plan on doing the same once I get an aftermarket exhaust
    Sent from my SM-G930V using Tapatalk
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by aliensporez View Post
    You're in Houston too, I'm going to CN MUFFLER this weekend ;)
    - iKe -
    2011 S5
    2011 A4 Avant
    Established Member Two Rings Mikeyloureiro's Avatar
    Aug 27 2013
    Rockville centre/new york
    I removed the resonator on my stock dp, also had awe track. And my friends car, with awe none res downpipe and awe track sounded much nicer than mine. Weird i know but i would say dont cheap out and buy the downpipe
    May 31 2016
    Houston, Texas
    Let me know how it goes!
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by Mikeyloureiro View Post
    I'm not cheaping out LOL, any chance you have sound clip on yours? I've seen bunch on youtube for AWE non res DP/AWE track combo (btw I have AWE track exhaust as well).
    - iKe -
    2011 S5
    2011 A4 Avant
    Aug 27 2013
    I got the jhm catless test pipes installed and went to the touring exhaust cause its so loud so im on a completely different setup now
    Aug 14 2013
    Maplewood Nj
    if you don't mind me asking how much did you pay to get the test pipes installed because I have them but this shop where I was going to get the test pipes and non res downpipes installed originally told me 250 for both then called after I dropped the car off and said I would have to charge you 12 hours of labor just for the test pipes. I ended up just getting the downpipes installed for 150
    Aug 27 2013
    Quote Originally Posted by Blakout144 View Post
    700. Took around 12 hours lol. Jhm claims u dont have to drop the trans but my audi tech that installed it couldnt install it unless he lowered the trans
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    Short clip but... AWE TRACK with non res stock downpipes... I'm happy with it! I'll make a better video soon.
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Veteran Member Three Rings TTRStud's Avatar
    Jul 12 2013
    Jacksonville, FL
    Quote Originally Posted by DreDay View Post
    How's the drone inside the cabin with the windows up? Just curious. Thanks.
    '10 Meteor Gray Metallic S5 Prestige Loaded 6MT - AWE Track - PCed OEM Rotors
    Apr 25 2010
    Morris County, NJ
    @TTRStud drone isn't much of an issue, especially with the windows up. The cabin does a good job of muffling the noise, I don't know how loud the car is unless I'm outside. It drones when you are too high of a gear or course, but besides that not bad.
    Jul 12 2013
    Jacksonville, FL
    Thanks! I guess I should have asked...any discernible difference in drone (not volume/loudness) in going from resonated to non-resonated?
    Also, are your fogs hid's, bulbs, or simply overlays over the glass? Love'em and going for the same look :)
    Thanks again!
    Feb 21 2007
    Houston, TX, USA
    Tks Dreday!
    What do you guys think compare to this clip?
    https://youtu.be/xA8GmyV25vQ
    - iKe -
    2011 S5
    2011 A4 Avant
    May 31 2016
    Houston, Texas
    Tks Dreday!
    Sent from my iPhone using Tapatalk[/QUOTE]
    Apr 25 2010
    Morris County, NJ
    @TTRStud a bit more drone maybe? Again, not enough to bother me. Manual is key, I don't know if I would have done it if I had a DSG.
    My fogs are bulbs! I got them from an eBay member.. Can't find the link because it was a while back. I'll look for the box and message you a picture when I find them. They were cheap and look awesome. Thanks!
    Feb 21 2007
    Houston, TX, USA
    Well, mine is DSG..and I can hear drone a bit so do you think if I remove the resonator will make the drone louder in the cabin?
    - iKe -
    2011 S5
    2011 A4 Avant
    Apr 25 2010
    Morris County, NJ
    From what I've read in other posts, folks tend to avoid non res with DSG...I guess if you ride in sport or something it might not be as bad. It depends on what you can handle? Luckily the AUDI cabins are so well insulated that outside noise is mostly muffled. I would maybe look up some videos with non res DSG on YouTube. Might find something?
    On a side note, you can get these removed, and if you don't like it, reinstalled for probably half the price of a new AWE non res DP.
    Aug 27 2013
    this is my 6MT JHM Catless test pipes. AWE none resonated downpipes and AWE touring exhaust WOT run. Loud inside the cabin, sounds terrifying just how i want it. I had the track exhaust but that was way way way to loud with the catless test pipes
    Jul 12 2013
    Jacksonville, FL
    Please let me know when you find the box! Also, how's the rubber seal around the bulbs' bases? Do they deal properly? Many aftermarket bulbs lead to condensation inside the housings. Thanks!
