Results 1 to 10 of 10
    Established Member Two Rings Rkost's Avatar
    May 28 2015
    Arizona
    Mechanical question
    Hey everyone, I looking for a few opinions. I currently have a 2011 3.2L with 79,500 miles on it. I bought the car last year and purchased the extended warranty through the dealership. I have about 2 years or another 20k miles left on the warranty. I can cancel the warranty and get a check for about $1,800.
    Any thoughts or experience with this model and is it worth it to keep the extended warranty? I've never had an extended warranty but I've heard they're known to wiggle out of any repairs.
    And before anyone makes the comment, I would absolutely love to buy a used SQ5. But I don't have the green to do so right now
    Thanks everyone for any input.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    3.2 NA engines with high mileage have a really bad Carbon Buildup history.
    If you keep it, keep the warranty and engine/drivetrain a warranty in tact.
    As long as you service it at the dealer you should be fine if you like the car.
    If you have something else you like, take the check and get the new ride.
    If you like what you have keep it as long as you have warranty. Then get out before it's gone.
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    May 28 2015
    Arizona
    Thanks man, I was pretty sure that was the answer I was going to get but I wanted to comfirm.
    May 28 2015
    Arizona
    So after Thunderdent's advice I kept the warranty. I took the car into the dealership for an oil change 2 weeks and that morning I get CEL. I pulled the codes and I'm getting a misfire in either one or two cylinders.
    The Dealership has now replaced a fuel injector and has had the car for over 10 days. But they are still getting the misfire. Now they think one of the cams could have a flat spot? Not sure how that happens.
    The extended warranty company has flown out and has asked that they open up the engine so they can do an inspection. My advisor is telling me once they open up the engine the Warranty Company could say no its not covered and I would be on the hook for $2k to reassemble the engine.
    The warranty is not through Audi, it was a used car warranty. But I bought the highest level that should cover just about everything.
    Does anyone have any experience or thoughts on this, I have to give my advisor the okay to open it up this week.
    I would think Audi could figure out a misfire issue and not have to pull apart the whole engine!
    May 28 2015
    Arizona
    My concern is the warranty company is looking for something they don't cover and leave me completely high and dry with an engine fault and no coverage.
    Established Member Two Rings goblues38's Avatar
    Aug 14 2016
    STL
    yeah....that is why it is advisable to stay away from aftermarket warranty providers. You are basically at their mercy.
    At this point, you almost have to roll the dice.
    Good luck.
    May 28 2015
    Arizona
    Thanks man... if it doesn't work out its going to be an expensive lesson.
    Sep 22 2016
    Houston, TX
    Which 3rd party warranty company is this? I just purchased a 2011 Audi Q5 with 3.2L and currently shopping for an extended warranty. Fidelity seems like the one everyone goes for here.
    May 28 2015
    Arizona
    Quote Originally Posted by ThunderDent View Post
    I wanted to give a big thank you to Joel and everyone for your comments for confirming what I thought about keeping my extended warranty... took the Q into the dealership for an oil change and happened to get a CEL that morning. Talked to my advisor, he looked into it and there turned out to be a worn roller and valve spring causing the misfire. Extended warranty flew out twice for inspection and in the end covered it in full. Saved me $3k for the service. Took them 6 weeks but I finally got her back today!
    May 28 2015
    Arizona
    And they did some carbon clean out while the engine was open! BOOM!
