Results 1 to 13 of 13
    Oct 04 2015
    East Coast
    Replaced ballast, Headlight still flickering and going out.
    So my headlight has been flickering and going out for a while now but has recently gotten so bad it goes out about every ten seconds. Can't really drive at night with a headlight out so its a bit of a problem. When I was doing my timing belt and had the bumper off I switched the headlight bulbs around so I could tell if it was the ballast or the bulb. The flicker remained on the drivers side so I figured it couldn't be much else other than the ballast. I ordered a used ballast offline for around 115 bucks as I didn't want to fork out 250 dollars at the moment and I just finished putting it in and reassembling the bumper. When I tested it the same thing is happening, It will go on for a short while, then start flickering, then completely go out. If I turn off the lights then turn them back on it comes on again and the cycle continues. I'm not sure where to turn as I thought I eliminated everything it could be, could there be a loose connection or something inside the headlight assembly? Thanks for the help!
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    If they are flickering and a off-on will turn them back on, this usually points to the bulb going. I would definitely buy new bulbs if you haven't done that yet.
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Oct 04 2015
    East Coast
    Quote Originally Posted by supple View Post
    Yeah I guess I'll try that as my next step but the fact that I switched the bulbs around and the flicker stayed on the drivers side seems strange.
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Phil will eventually chime in...
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Quote Originally Posted by Hugh@EuropaParts View Post
    LOL beat me to it.
    Ivan
    Oct 16 2008
    South Florida - Ft Lauderdale
    Assuming that you car came with xenons from factory, did you, with VAGCOM, marry the installed ballast to the ECU?
    Phil
    Oct 04 2015
    East Coast
    Phil
    No I didn't, I don't even have a VAGCOM... lol. Do I need to do that?
    Oct 16 2008
    Yes sir
    Oct 04 2015
    East Coast
    Yes sir
    Oh boy... alright is there anyway I can do it without buying VAGCOM? Money is a bit tight right now.
    Oct 16 2008
    Google VAGCOM LOCATOR and see if you have someone around you who has one that you can borrow
    Oct 04 2015
    East Coast
    I wanted to ask since I've never used one before, is there a guide on how to do this? Also I read somewhere else that you shouldn't have to marry the ballast to the ECU not saying you're wrong just curious why theres different opinions on it.
    Oct 16 2008
    Yes
    On rosstech websire
    Oct 04 2015
    East Coast
    EDIT: Nevermind
    Last edited by Bill Jenkins; 08-11-2016 at 07:12 PM. Reason: Realized the link wasnt a legit product.
