Results 1 to 7 of 7
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    S6 Calipers possible
    I found a set of S6 calipers locally with RS7 rotors.. does anyone know if they will fit on our cars?
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by miA4 View Post
    Anything will "fit"... what you need to figure out is if your wheels will clear or poke out by 1000mm
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Deactivated Four Rings
    Jun 23 2011
    I just looked at an RS7 here and you will need at least a 19 or 20 " wheel to clear that rotor and if the S6 calipers are close to the size of the RS7 you will need a lot of caliper clearance.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I just picked up parts from a guy (Euromin) that runs RS6 brakes all round on his B5 A4 avant. Having said that, he was on 19" wheels and they were close. He also had to swap the uprights. I guess my point is that it can be done (B5-B7 are all fairly similar), and the S6 calipers are definitely smaller than those of the RS6, but it'll be more work than is required for other, proven swaps. Unless you're getting them for dirt, it'll likely cost more than a 17z or 18z swap.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jun 23 2011
    If they are new C7S6 calipers they are probably bigger than the C5 RS6.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by james12lucy View Post
    B5 and B6/B7 are nowhere near similar. What year S6? ... if it's an old S6 it might not be much of an upgrade as the B7 A4 shares the same calipers as a B6/B7 S4.
    Hugh
    Jun 27 2011
    the C5 platform A/S6s share the same hub layout so the brakes should be bolt on. Can't really say the same for C6 brakes, I have no idea.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
