Results 1 to 9 of 9
Thread: S5 Bike Rack
    Senior Member Two Rings a4innov's Avatar
    Nov 29 2004
    Toyota Highlander
    willow glen,ca
    S5 Bike Rack
    Hello all I'm hoping to get a little help. I've been researching a bike rack for my 2015 S5 but haven't had any luck so far. I've seen a couple of post with some sort of rack installed but don't know what brand or model it is. Can someone help with this.
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    https://www.seasucker.com/shop/1187/#tab-description
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    ^I had the SeaSucker.. Best rack on the market
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Nov 29 2004
    Toyota Highlander
    willow glen,ca
    Thanks for the responses. The rack looks good, but should I be worried about it falling off.
    Sep 05 2014
    Couple things and you should be fine
    Make sure whatever surface you're attaching to is clean
    Take it off whenever you aren't using it vacuum will slowly lose suction if you leave it on long term
    Each vacuum cup is rated for 210 lbs so unless all 4 fail simultaneously your bike isn't going anywhere
    Ken
    2021 Q5e Prestige
    District Green
    Established Member Two Rings CG3D's Avatar
    Feb 28 2011
    Kenosha, WI
    I have a seasucker. Highly recommend it. Super solid and easy to use.
    I love that I can take the whole deal off in 10 secs when I dont have a bike on it. I take a small spray bottle of water with me when i use it and just wet the cups and it goes back on.
    There are racks out there that can look decent without a bike on it, but to me I got this car because of how it looks, and to me the best looking bike rack is no bike rack.
    2009 Audi S5 | Meteor Gray | Magma Red | H&R Sport | BBS CH-R 20x10.5 | AWE Track | Drive Select | Side Assist
    Past: E55 AMG, 1970 Nova
    IG: @CG_3D
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    Here's mine, on OEM rack and rockymounts.
    - iKe -
    2011 S5
    2011 A4 Avant
    Active Member Two Rings Alex100's Avatar
    Aug 01 2016
    Dallas, TX
    Car lowered? How much?
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by Alex100 View Post
    Lowered? yes
    How much on the bike rack? It was on sale 2 months ago (ECS TUNING) $125.
    - iKe -
    2011 S5
    2011 A4 Avant
