Results 1 to 12 of 12
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    some Downpipe work
    Hey guys,
    so after talking to a friend who does good exhaust work, I am thinking of getting some exhaust work done.
    first option is to get the precats removed and have the second set of O2 sensors relocated to behind the main cats.
    or
    leave all O2 sensors as they are and remove the main cats.
    I am really just looking to get a deeper exhaust tone and have a less restrictive exhaust system.
    any info on either option and what would be the best way?
    Senior Member Three Rings Gansel's Avatar
    Apr 09 2015
    Vancouver
    Quote Originally Posted by skhan91 View Post
    Hey guys,
    or
    Are you currently running stock? If so id do piggies pipes and x pipe and then lock the valves open via golf tee or something similar.
    Im working hard now so my future daughter doesn’t have to sell protein powder on Instagram - 08 RS4 - Insta: @gansel
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    i have already got an xpipe with the stock setup. im essentially looking to do piggies which is just gutting the precats but wondered if anyone wiuld have done option 2 which is remove the main cats?
    Sent from my SGH-I337M using Tapatalk
    Established Member Two Rings seblove's Avatar
    Feb 28 2013
    los angeles, ca
    You would (eventually) throw a code with either option I'm pretty sure, so plan on either tuning it out or having your guy do some 02 spacer trickery. Piggie piping will give you ~10% increase in volume without much change to the tone, maybe slightly "tinnier" and ever so slightly more bassy if that makes sense. Removing the main cats would make the car a shit ton louder and wouldn't sound all that refined on a stock exhaust setup imo. Neither option is the route I would take on the rs4 - i think it deserves a dedicated aftermarket exhaust or nothing at all.
    Getting a full exhaust on this car was the funnest and most rewarding mod I've done - the motor makes some incredible sound when you let it loose but remains refined and exotic across the power band. Even just a catback is a better option because you won't have to worry about CEL codes and you'll get the added volume + desired tone (with some simple youtube research). Also, piggie piping just means your main cats will be under more stress down the line and will collapse earlier than they otherwise would have - happened to me first hand on my old s4.
    2008 RS4 Satin Pearl wrap - JHM stg 1+ blower - full JHM exhaust, resonated & catless - JHM LWFW & 3R clutch - PSS9s + 034 control arms & sways - JHM short shift + linkage - Apikol Rear Diff Mount - Stern Motor Mounts - 034 Snub Mount - 034 Trans Mount - JHM IM spacers
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by seblove View Post
    hmmm. thats good to know. its strange though, so many people are saying that piggie piping is one of the best mods available on this car and that it frees up the engine in a really good way? I will eventually get a full exhaust (hopefully JHM) but even then i would wanna do something with my DPs. this just seems like a much better option then spending almost 4x as much on JHM downpipes
    Veteran Member Three Rings bluebull's Avatar
    Aug 29 2014
    2017 R8 Nardo boosted with VF; 2017 SQ5; F250
    Portland, OR
    Full JHM with resonate and high-flow cats + vband test pipes for easy swap.... best mod ever (besides a supercharger!)... $3850 best money spent!
    Mar 14 2014
    E46 M3 [sold] | Audi RS4 [sold] | 2010 GTI [sold]
    Northern Ohio
    I have piggies and I continually get asked what aftermarket exhaust setup I run. It really opens up the exhaust and sounds great. the exhaust burbles more but is still pretty quiet at lower RPMs. O2 Spacers were needed on mine, but I didn't relocate the sensors holes and I am not tuned (although I need to replace two of my sensors that were seemingly harmed during the process as the passenger side pipe is throwing codes while the drivers side is not complaining at all).
    Like you mentioned, I did mine after reading about all the folks that are saying that is one of the best initial options - and I don't regret it at all. JHM even offers a nice service of gutting the precat along with the relocation of the sensor. I say go for it.
    2015 Sepang S3
    APR Stage II [ ECU & TCU ] AWE SwitchPath Exhust | APR downpipe | Neuspeed RSe102 wheels
    Established Member Two Rings Sleepin On 18s's Avatar
    Aug 31 2015
    '07 RS 4 _____'12 Touareg Lux
    Baltimore
    I had the big rear resonator deleted, and two mandrel bent SS straight pipes welded in place. They did a fantastic job, and it really "woke up" the car. Got a significant bump in volume (imagine pressing the S button like 3 more times), and some nice burble/backpressure sounds that I love.
    quattro GmbH made a masterful OEM exhaust for our RS4's. If you look at the system underneath it is absolutely gorgeous. I would not hack up the DPs or cats. Either do a resonator delete for more volume/grumble, or purhcase/install some JHM gutted Piggies - or both!!! I can't afford another $3000+ on exhaust right now, so this was a fantastic option for me. Holler!!
    '07 RS 4 // DGP, Stoptech Aero, JHM Trio, 034 Mounts, Res delete, Hella Horn (dreams do come true!!)
    '06 A4 3.2L S-Line // Rare Blk/Blk/Blk 6spd, Alum Trim, Nav/BT (amazing car)
    '03 A4 1.8t // Blk/Blk 6spd (even w mods, didn't love 4 cylinders)
    '98 A4 2.8L // Blk/Blk 5spd (heavily modded, won some shows)
    '96 A4 2.8L // Pearl Wht/Blk 5spd (first love, Quattro for life)
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by Sleepin On 18s View Post
    but arent JHM piggies exactly the same thing as "hacking up the DPs" ? they simply hollow out the precats and relocate the O2 sensors? the cost for this mod through JHM is about $400 and about $100 for shipping to Canada (where i am) I have a chance to get this done locally for about $200
    Apr 09 2015
    Vancouver
    Did you find a local shop to do it for you? $200 isnt so bad at all. Im also in canada and have the same duties and shipping issue as you.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by Gansel View Post
    yes i did! the car has an appointment booked tomorrow and I have to decide whether i want to take the main cats out or the precats. This is a city reknown exhaust fabricator so the work should be good!
    Yea i just cant justify paying almost $700 CAD for JHM piggies when its about 1/4th of the price to get it done here locally
    Veteran Member Four Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    Do the pre-cats. Where are you having it done?
