Results 1 to 6 of 6
    Established Member Two Rings cooncified's Avatar
    Oct 16 2013
    Orange County
    3.0T Intake install throws MIL - MAF
    Anybody have issues installing aftermarket intakes on the 3.0T and throwing a MIL code after about 50 miles? It happened to me last month and I have been too busy to ask. Code had something to do with the MAF sensor, I need to check the specifics again.
    I installed an Injen intake without the factory box.
    The hose that normally clamps to the bottom of the intake box didn't seem to have any function but I was not able to figure out what its for? Additional air inlet?
    Established Member Two Rings stingvb's Avatar
    Sep 13 2009
    2015 Jetta TDI on loan from VW
    Western Burbs of Chicago, IL
    I have never seen any error codes, but I left the stock air box in place. Good luck with the fix.
    Established Member Two Rings Davor_'s Avatar
    Nov 10 2015
    St. Paul
    I've got that intake without the box and I got a filter for that hose that's on the bottom of the factory box
    No codes.
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    i've ran Injen both with and without airbox, no issues.
    as for hose at the bottom, just get a vent air filter for it.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Oct 16 2013
    Orange County
    Thanks guys. I went back to stock and the code cleared itself. Good to know I shouldn't have had a light on with this intake. I will give it another go, maybe run the airbox this time.
    I NEED the SC whine back :)
    Nov 10 2015
    St. Paul
    Just make sure you have the car locked with the hood up for at least 10 min before install (apparently that puts the ecu in off mode or whatever you wanna call it)
