Originally Posted by
rollerton
Kind of sounds like the water pump went. If it seized (briefly?) then possible you'd lose power steering and alt light would come on. Sounds like a strange situation.. They have a 'weep hole' that will let coolant drain out under certain kinds of failure.
If there ANY noise at all when running now? Can you tell if the water pump is moving any coolant? Does coolant just drain out without the engine running?
Go over all the coolant hoses and clamps that you can get to, but that particular leak does seem to come down front of the block from the pump...so, what truly happened could be moot point, since sort of looks like you have to dig into the water pump area anyway.
Only some disassembly will tell..
I checked all hoses and lines and they all look good. I can't tell yet if the water pump is moving water correctly, as soon as i pour water in it drains out of the same area immediately, whether the car is running or not. I do not hear any weird sounds like a failed water pump bearing, it is possible just the seal failed? & the leaking coolant caused the belt to slip which caused the loss of power steering and battery light?
Here is a video of my car running right now, it sounds fine, but there is no water in it.
http://vid772.photobucket.com/albums...pshev4zdke.mp4
