Results 1 to 24 of 24
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    rattle noise on engine start
    Hi there,
    a friend of mine has a 2014 B8 S4 with stronic and the quattro sports differential. There is an unnormal rattle a few seconds after you start the engine.
    Here's a soundfile:
    Car has pretty low milage of about 10,000 miles. The local dealer changed timing chain tensioners, did an oil change and did a basic setting of the dual clutch transmission.
    The noise is still there. The dealer now says it is normal and nothing to worry about, but in my opinion this does not sound "healthy".
    What I can say about the noise:
    1. It appears on 3-4 out of 10 engine starts
    2. It mostly happens on cold engine starts
    3. It also sometimes happens with a warm eingine ( >70°C coolant, >50°C oil temperature)
    4. If the last run of the engine was <5min and not driving faster than 15mph, there will be no noise on the next start, even if the car stands for 1 week.
    Any thoughts where this comes from?
    2014 Audi S5 3.0T STronic // Estorilblue
    VAG Coding and retrofit expert
    Oct 02 2013
    Redstone, CO
    Well my initial response was the tensioners.
    http://www.audizine.com/forum/showth...rt-V6-3-0-TFSI
    I had them replaced on my car a week ago and it no longer makes any odd noise at start-up.
    You say that's already been done although is certainly sounds like my car did before the repair. Everyone at my dealership claimed the tensioner "rattle" is perfectly fine unless it's more than 3 seconds or so. I'm really not sure what direction you should go here. Perhaps someone else has a clue but from the video, it don't hear anything that sounds terrible to me.
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    Sep 08 2015
    2009 VW MK6
    Germany
    The noise is at 0:13 in the video. As you can hear the engine is already running and not rattling at all, then after 0.5sec there is this high-pitched "grrrr". It really doesn't sound like on all the timing chain tensioner videos online, where the rattle is there directly from the start.
    I would also say it comes more from the lower end of the car but it is really hard to locate.
    Apr 04 2012
    MSP
    Normal... Mine's done the same since new.
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    If it's a rattle right after turning on - definitely the tensioner. There was a TSB for it. Had it done recently...but this doesn't sound like the tensioner, unless the video just isn't that clear
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Sounds like normal VW/Audi engineering so in other words .. who knows.
    Nov 11 2010
    Ontario
    I'm in Canada. Same noise. Asked about the tsb. They said there is no tsb for that here.
    In the end they called Audi Canada I guess and are replacing the tensioner under warranty.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Secondary Air Injection Pump?
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    Mine makes the same noise and I never gave it a thought.
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    Quote Originally Posted by def View Post
    Did they have to replicate the noise at the dealer? Mine does it occasionally on cold starts but it's not incredibly frequent so I worry they won't cover it unless they keep it for a week.
    Established Member Two Rings crimson773's Avatar
    Aug 08 2014
    2021 EZGO RXV
    ATL
    Mine makes that noise too and I believe has done it since I've owned the car.
    Nov 11 2010
    Ontario
    Quote Originally Posted by LittleDozer View Post
    Yes. I had to leave it over night. They confirmed in the morning.
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    Yep mine has always done this since day one.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Just wanted to chime in and say that my car does it too. I always just thought it was normal. *shrug*
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Normal
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    mine does it as well.. i thought it was my exhaust, but I can't replicate it otherwise. I can definitely hear a similar noise if I'm driving when the car is somewhat cold. It's buzzing through my exhaust. After the car warms up, it's silent though.
    Established Member Two Rings nickskeeta's Avatar
    Nov 30 2014
    Hollister, Ca
    Mine does it as well, sounds normal
    @nickskeeta
    2011 S4 6MT Meteor Gray Pearl
    2018 Silverado 6.2 LTZ
    Dec 21 2013
    Same here, had this noise since day one
    Current: 2021 R8, 2019 A6, 2017 Ghibli SQ4
    Past: 2009 C300, 2011 C63, 2013 535i, 2014 S4, 2016 M4, 2016 Macan, 2017 Macan Turbo, 2017 E350, 2017 750i, 2018 Panamera Turbo
    Dec 19 2010
    North CA
    Does the noise go away after a fresh oil change?
    Established Member Two Rings TheAsset's Avatar
    Jul 14 2016
    MO
    This....This is what a good rattle sounds like. Mine is going into the dealership tomorrow. 2013 S4 with 25k miles.
    https://youtu.be/4JrR04p1rYk
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    ^ that's worse and longer than mine. Mine admit 3-4 rattles, less then a second.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Yeah, that's a rattle. Mine does what the OP's does. A little short buzz sound. Almost sounds electrical rather than mechanical.
    Dec 19 2010
    North CA
    Bad injector maybe?
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    For the first 55k miles my car has never made this tensioner, rattling noise. Around 55k it started doing this when first started in the morning, before sitting overnight. Last weekend the car sat from Friday evening through Sunday evening and it rattled for about a whole 5 seconds versus the regular 2 seconds for when sitting overnight.
    What happens to a TSB outside of warranty? Is it considered an out of pocket repair? I turned 58k yesterday and of course I'm modded so they might be reluctant to cover anything.
    2018 Carrara White Audi Q7 3.0T P+, Cold weather package, Vision package, Warm weather package, Driver Assistance package and towing package
    Stock
    2016 Mythos Black Audi S3 P+, Black Optics Package, Tech Package, LED Lighting Package, B&O, Red Calipers
    Modded
    2001.5 Brilliant Black Audi S4 Sedan 6MT
    Stage 3
