Hello, I have an '02 3.0 with the 5 speed automatic tiptronic in it. The 5hp19 transmission. I've had the car for over a year now. I was getting the p0751 code. I replaced the neutral safety switch, didn't fix it, replaced the oil and filter with genuine Audi oil and filter, didn't fix it, was also getting a code for tiptronic switch which was outting it in safe mode so I changed that as well, didn't fix it. Finally I was able to hook it up to a vagcom and it said shift solenoid A stuck on short to ground mechanical damage. So i bought a whole used valve body from a perfect driving car with solenoids and everything. Still same thing. the transmission just goes into safe mode. I hooked up vagcom and did a test for the voltage and I noticed that the volts greatly decreased as soon as the car went into limp/safe mode. Could this be something electrical? The dash also keeps telling me that all my turn signals don't work even tho they do.. Can something electric in the car other than the transmission interfere with the transmission? Also thinking maybe the engine speed sensor or the transmission speed sensor? Maybe tcu/harness? I'm tired of throwing money at it and just having it sit around collecting dust.. Any help would be greatly appreciated.
Also thanks to the diagnosticator for helping me out a lot last year
