Audi S8 Brembo calipers (similar to Porsche Big Reds; 993tt)
- 2 Audi S8 Brembo calipers (4D0-615-107-D) with new pins
- 2 stainless steel lines with fittings
- 2 sets of used Texar T4045 FF track brake pads; around 95% remaining (17.45 mm thick)
Other than the color, the outward appearance is almost identical to the Porsche Big Reds (993 twin turbo).
The Porsche uses the quick release pin for the pads and the Audi uses the two pin design. Both use dual pistons on each side, but the Porsche use 44mm and 36mm on each side, whereas the Audi uses 44mm and 40mm. Audi has about a 10% piston square area size over the Porsche. The Audi caliper can also use a slightly thicker (by 2mm) front pad than the Porsche.
List Date: 8/1/2016
For more info, click here to view the original listing: Audi S8 Brembo calipers (similar to Porsche Big Reds; 993tt)
This item is no longer available.
