Results 1 to 6 of 6
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    Laptimer boost gauge = actual value (I have no boost)
    This might be a known item, but I always wondered if the boost meter on the laptimer screen was displaying actual values or the value specified by the ECU. I can confirm its the actual values, as I appear to have no boost (again) for some reason. Im going to take the car in for service to have this fixed, but I thought I would share what I discovered on that. :)
    I confirmed this by logging actual and specified with VCDS, and I can clearly see the specified value rising through acceleration, and the actuals only climbing slightly. This is the second time this has happened. The first time was a cracked vacuum line.
    -j
    Current:
    '13 S7 (Innovation, B&O, LED's, AWE Exhaust, RS-Grille) -- '12 FJ Cruiser (Heavily modded) -- '14 QX80
    Gone but not forgotten:
    2014 Porsche Carrera S -- 2014 Toyota 4Runner -- 2002 Acura TL-S (My first 'luxury' car)
    Established Member Two Rings ke116ngc's Avatar
    Jun 27 2011
    Denver Metro
    Did the car throw any codes when you checked?
    2013 Audi S6 - Phantom Black Pearl Effect, Black Interior & Headliner, Driver Assistance, LED Headlights, Cold Weather, 20" Wheels, Piano Black Inlays
    APR ECU Stage II Tune, APR TCU Tune, APR Downpipes, AWE Touring Exhaust, AWE S-Flow Intake, Eurocode USS Sway Bar & End Link Set, Eurocode Alu Kreuz, Adam's Rotors Slotted/Dimpled, Porterfield R4S pads, Stainless Steel Brake Lines, 034 Motorsports Driveline Mounts Package, RS Grille, H&R 20mm DRA Spacers, Vagcom lowered.
    Established Member Two Rings SITH7's Avatar
    Jun 30 2016
    Boca Raton, FL
    I notice this happening to mine from time to time. Especially as it fights with the transmission (I have the TCU flash). Even more odd, is my shift lift doesn't seem to work - yes I know it needs to be in manual. Am I crazy?
    2018 Q7 Prestige Brilliant Black
    Full SQ7 Body | S-Line Flat Bottom Steering Wheel | Carbon Fiber Interior Trim | S-Line Perforated Shift Handle | Euro Sweeping Tails | 22" Black S-Line OEM Wheels
    SQ7 Exhaust Conversion & CETE Lowering Module
    2016 S7 Brilliant Black
    Parted out and currently awaiting surrender to next owner with mixed feelings.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by SITH7 View Post
    Do you mean shift LIGHT?
    I addition to manual mode, the light is only on the HUD when the lap timer is selected in DIS & only if you don't have NAV or ACC guiding you as that supersedes the lap timer.
    Hope that helps.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jun 30 2016
    Boca Raton, FL
    Haha typing too fast. Yes the shift light...I thought it's displayed in the vis in lap timer?
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    For what it is worth, i had a boost sensor failure recently on one of the banks. It didn't threw an error on the display and was like in semi limp mode.
    Onl a vag scan showed there was an sensor failure.
    I still had some boots but very minor.....
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
