Results 1 to 9 of 9
    Nov 15 2015
    Central NJ
    Searched and still have Q's - which Oil is preferred for summer?
    Looked through the TSB list of "Audi Oil Quality Standard VW 502 00"
    Saw mobil 1 0W-40 listed. Was going to go with this, then figured why not ask to see if there's folks with experience who know of better options...
    Any prefs I should consider for this unusually warm NY/NJ summer? Anyone use a specific oil and end up with undesired noise (increased lifter noise, etc?)
    TIA
    LINK:
    https://www.audiusa.com/content/dam/...e-Bulletin.pdf
    Senior Member Two Rings MagillaGorilla's Avatar
    Nov 25 2015
    London Ontario
    Switching oil for the outside temperature is a thing of the past and completely unnecessary with modern synthetic oil. Run the type specified in your owners manual.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Oil has two weights 0W-40W - Operating temp and cold temp. No need to switch as the info is all contained.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Sep 12 2011
    2003 RS6 Daytona
    Syracuse NY
    I have super high miles now, running 5W-40 Liqui Moly. Have had good luck with it, Cheap on Amazon in my opinion for 5 Quart Jugs.. Granted I burn a quart every 250 miles, but whatever.. lol
    It's 502.00 compliant and factory calls for 5W-40 :)
    Veteran Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    Supercharged E92 M3, A3 E-Tron
    Orange County, CA
    5W-40 Liqui Moly is awesome.
    YouTube: DV Motions | Instagram: @danny.vuu @undisclosedm3
    []SQ5
    Nov 15 2015
    Central NJ
    5w-40 Liquid moly it is then. Thanks all!
    Apr 14 2016
    Austin Texas
    Quote Originally Posted by EddieK12 View Post
    Yeah. You should probably get that looked at.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    I've used motul specific and Castrol edge both in 5w-40 without any issues. You can use 0w-40 or 5w-40 depending on your climate. I only use oem or big name manufactures (Mobil1, Castrol, Motul, Amsoil, etc) for fluids and I haven't had an issue with any car, ever.
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Liqui Molly 5w-40. Just tried the "high tech" and I do notice a bit of a mpg increase as stated on the jug. I used to use Mobil 1 0w 40, but had to keep adding oil more often
