The past couple days when I move my window up/down I hear this crunching/grinding noise. I thought there was a rock or something that got stuck so I took it apart using this DIY. So there's nothing stuck in there and from a quick glance everything seems fine. I didn't try it out since I'm not sure it would be a good idea to hook up all the wires and close the window while it's disassembled so I'm not sure what the problem is at this point.
Before I put it back together, any ideas on what else I can try to fix the issue? Should I just go ahead and replace the window regulator (which from what I read is a common issue with Audis)?
Thanks
Edit: if it was the window regulator, does the brand matter? Here's a cheap one I found from Amazon:
https://www.amazon.com/Drivers-Windo...art/B007TYPH26
