Results 1 to 14 of 14
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    Spark plug removal at operating temperature for compression test.
    I have a few questions about a compression test.
    I have read that you need to do a compression test when the engine is at operating temp.
    But isn't it bad to remove sparkplugs on an engine that is hot?
    And if looking for a leak/scoring why cant you do a compression test on a cold engine. bacause you are looking at the difference between the cilinders right?
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    i believe the ASE mechanics like to do them on a hot engine with only 2 or 3 turn overs.... dry first, then wet
    i haven't really seen much difference between cold or hot, but definitely don't forget to pull the fuel pump fuse # 17 iirc
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    I've seen as much as a 30 point difference between a hot and cold engine
    Sent from the S4 with a Tap!!!
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by chain_slappins4 View Post
    mine was less than 5 psi, but that was just on my engine... i totally agree it should be hot for best results, but if he is just looking at the spread... then doing it hot and cold would probably give him more information
    Senior Member Two Rings b6dolphins4's Avatar
    Aug 07 2011
    Binghamton,NY / Raleigh, NC
    I'll do it at operating temp, with a 10 count to get a good reading
    2004 DG S4
    Mods:| JHM 93 Tune |JHM Stg 4 Clutch | 034 Light Weight Flywheel | Trexturk Cat less Dp's | Custom 2.5" Non-res Magnaflow CB | K&N Drop-in | 034 MAF hose | Apikol Snub/ Zero Gap Bracket | 034 Trans mount | JHM S.S. | JHM Knob |
    Apr 26 2016
    Metuchen New Jersey
    Quote Originally Posted by b6dolphins4 View Post
    a 10 count isn't necessary, maybe a 4 or 5 count.. a 10 count on all cylinders may kill your battery , but you really want to pay attention to the first stroke and make sure the throttle is open all the way
    Aug 07 2011
    I know it's just one of those things I do to be sure, havent killed a battery yet. Yeah I prop the throttle open with a wrench when I do it.
    2004 DG S4
    Mar 30 2016
    S4
    Oranjestd
    but won't you damage the threads removing spark plugs on a hot engine?
    and ive read that you can damage the coils if starting when disconected. is there also a fuse for the coils?
    Aug 07 2011
    Quote Originally Posted by Velox View Post
    I've done it this way on 2 separate s4's and haven't caused any damage. Not sure about the fuse.
    2004 DG S4
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    no fuse for coils, that would throw a code if you did anyway... never heard of this damaging a coil, but if you dont pull the fuel pump fuse... you will be washing your cylinder walls down with fuel (not good)
    Mar 30 2016
    S4
    Oranjestd
    One more question, what thread connector size do I need when doing compression test, is it 14mm?
    May 18 2012
    2005 S4
    Portland, OR
    I just removed all my coils when doing compression testing. No reason to leave them connected.
    Mar 30 2016
    S4
    Oranjestd
    Quote Originally Posted by 924Carrera View Post
    Yes, of course ,was stupid question, misread the article.
    Do you know the thread size I need for the compression test, is it 14 mm?
    May 18 2012
    2005 S4
    Portland, OR
    Yes, 14mm.
    This is a helpful guide regarding the NGK spark plug codes. The correct NGK plug for the S4 is a BKR6 series.
    https://www.ngk.de/fileadmin/Dokumen...en_code_en.pdf
