Originally Posted by
CoreyRS
Do the spherical options change the feel of the suspension?
RS4forfrank
Hi Guys,
Would like to understand why spherical would be superior to a polyurethane bushing like a poweflex product? My car is on the stock 19's happy with the handling, I don't track the car, and its not lowered, I just want the bushings to last longer and suspension to feel that solid feeling like when I had to replace the original rubber bushings. Also would bearings give a harsh feel to the car?
Interested to hear opinions and experience.
Thx.
Hey guys, to answer both your questions. I haven't run spherical, nylon or polyurethane on any of my cars.
But I gathered a lot of info from a couple of my racing friends and from other users on here which run track-setups, etc.
From soft to hard the materials go in this order: Stock rubber => Group N rubber => Polyurethane => Nylon => Aluminium
(detailed info for every type of material:
http://www.mc2racing.com/tech/20090130a/index.html)
@CoreyRS, yes a lot. The wheel geometry doesn't deflect under load. You wont get any unwanted camber or caster when cornering hard. The road response will be as direct as it gets. It will also greatly decrease all driving comfort.
@RS4forfrank, for your needs the polyurethane is the way to go. Just get the graphite-grease-matrix impregnated polyurethane bushings from Powerflex as the polyurethanes are stiffer than rubber and will produce "squeeching" if not greased and the impregnated ones are self lubricating (maintenance free). But be aware that a polyurethane bushing has a greater lifespan than OEM rubber, but it stil wears out. A metal or nylon bushing will out-live the car.
For my needs: I will be tracking the car and I want the suspension components stiff, so I will go for the metal options where possible and the rest I will make myself on a CNC from self lubricating Nylon.
