Results 1 to 8 of 8
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    MMI aftermarked Bluetooth and A2DP.
    I want to add the bluetooth function to my 06' B7, something similar to the FISCON unit that you can seamlessly integrate with the MMI system (https://www.kufatec.de/shop/en/audi/...plus-audi-seat). However I don't believe that this has A2DP as an option. I was wondering if anyone has found a unit that can be installed clean and hidden that also allows you to stream bluetooth audio through the MMI interface?
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Whatever you do don't buy an interface for MMI, that's a fibre-optic MOST based system which is NOT what's fitted to the B7.
    You need something labelled as compatible with the RNS-E, which is what the B7 has (yes I know it says MMI at startup, but that's due to an idiotic decision by a demented marketing person at Audi AG and has led to countless owners spending $$$ on MMI interfaces or map updates that are no use to them).
    One option would be to fit something that gives you an Aux input and then plug a tune2Air WMA3000B into the Aux input.
    The best OEM way is to swap the RNS-E to a 2010+ version and replace the glovebox CD changer with a CAN version of AMI, then connect a tune2Air WMA3000A A2DP interface to the AMI.
    WMA3000A/B link: http://www.viseeo.com/ugC_ShowroomIt...0&hidShowID=22
    Mar 22 2015
    2012 Mini Countryman S
    Va Beach
    Grab this and plug and play your way to BT streaming. http://www.audizine.com/forum/showthread.php?t=718095
    Sent from my HTC 10 using Tapatalk
    Jul 05 2016
    Ontario, Canada
    Quote Originally Posted by PetrolDave View Post
    Thanks for the heads up on the RNS-E
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    http://www.ebay.com/itm/BT-Bluetooth...UAAOSwepZXQtTi
    http://www.ebay.com/itm/iPod-iPhone-...YAAOSw6btXQs3- I use this on my s4 with rns-e and work perfect u can call and listing music also work like virtual cd (mp3 player)
    http://www.ebay.com/itm/BT-Bluetooth...sAAOSwrklVMNkl this is on my A8 work also perfect
    Jan 14 2007
    Hampshire, U.K.
    Quote Originally Posted by xhackerekx View Post
    That's a fibre optic MOST interface, so not suitable for a B7.
    Jul 23 2007
    for b6/b7 with rns-e look for 2nd link
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    I just hardwired a BT receiver to an ignition power source and tapped into the AUX Input on the back of the RNSE. There's no functionality in the RNSE, but the sound comes through great.
    Plenty found searching on this topic...
