Results 1 to 6 of 6
    Senior Member Two Rings UWbadger91's Avatar
    Apr 03 2016
    Wisconsin
    4" Tips that fit OEM catback without modification?
    Hey guys, I've been considering either keeping the stock catback and getting 4" tips or getting the AWE Switchpath. At this point I feel that new tips would be the best option. Does anyone know if there are any tips that bolt right on without any modifications? I talked with ECS and they said theirs would require modification and have not seen any that big that are direct bolt on. Any help would be greatly appreciated! Thanks!
    Apr 03 2016
    Wisconsin
    Bump
    Apr 03 2016
    Wisconsin
    Up
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    So far none. Only option is to chop off the oem inner piping where it starts to become oval and weld on larger tips. Many forum members have done it.
    -cW
    2023 X3 M40i Alpine White
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    I have a set that is carbon fiber and SS no logo 101mm and you still have the cut the oval part off but they fit with any rear diffuser because I had the slip-on part lengthened to fit nicely on out cars.
    And I have a set of these as well that I am selling for $150, they are 90mm tips
