Results 1 to 2 of 2
    Registered Member One Ring Nik.goodnow's Avatar
    Jul 30 2016
    '02 VR 6 Jetta '03 Dodge Ram 1500 '01 Subaru Legacy
    Pawling NY
    '02 B5 S4 Stage 3+ 420hp
    2002 Audi S4
    2.7L V6 Biturbo Stage 3+
    420 HP at crank AWD 6-Speed
    ALL PARTS REPLACED IN LAST 15K MILES:
    FTG KO4 Turbos with upgraded plumbing (24lbs of boost peak)
    Upgraded aluminum 85mm MAF and Bipipe
    Walboro 450 Fuel pump with Bosch 550cc injectors
    075N diverters and boot, n75 valve and new vacuum lines
    New valve cover gaskets, rear main seal, timing belt, water pump, T stat, front axles, upper control arms and strut mounts.
    Sits on RS4 Avant springs: Lowers 1.5" in front 1.3" in rear (Stiffer spring rate in rear, rides nice especially for a DD)
    Lower Control Arms have less than 1K miles
    Transmission was replaced at Aprox 130K and now has 100K on it. Also installed lightweight flywheel with Stage 4 6-puck Kevlar race clutch and throw out bearing.
    Also, new performance motor and tranny mounts.
    Has Piggie Pipes for exhaust. (Hallowed factory pipes to single rear muffle))
    Tuned professionally by Daz Dillinger in FL
    Has anti-lag and "No-Lift-Shift"
    Has Zietronix wideband AFR data logging gauge installed and mechananical boost gauge.
    VIS Racing Fiberglass & CF hood w/ AeroCatch latches, RS4 front bumper
    Front Tires have 1,500 miles on them
    Just had it professionally compounded, waxed and detailed.
    K&N Air filter
    Stock brakes unfortunately :/
    I know I've got to be forgetting a few things.
    Car has 172,XXX Miles
    3rd Owner
    Originally a Georiga car, then brought down to FL so it's pretty clean.
    Just drove it up to NY for the summer, made the trip no problem.
    Solid car, no check engine lights.
    Everything works as expected.
    Small crack in rear bumper cover driver side. From previous owner backing into a tow hitch in his driveway...
    Price drop, need gone b/c I'm moving.
    $6,500 OBO
    Call or text anytime:
    Nik
    386-316-3440
    Jul 30 2016
    Pawling NY
    Message me if you'd like more pictures.
    Clean title no accidents.
