Results 1 to 11 of 11
    Established Member Two Rings truethat72's Avatar
    Jul 25 2014
    San Antonio, TX
    VW/Audi DSG Gearbox Issue
    A friend of mine just emailed me his recent experience with his S4. Anyone know about this?
    The main control unit in the DSG gearbox is called a “mechatronics” unit. It’s a $1500 part that is inside the gearbox surrounded by transmission fluid. VW and Audi filled the transmissions with synthetic oil at the factory but it has been found that the oil reacts (sulphur) inside the transmission and damages the mechatronics control unit. The fix is to drain the gearbox and fill it with mineral transmission oil. However, the VW Group didn’t discover this until recently and have been not willing admit the problem worldwide as 1.6M cars would be affected: http://www.autoblog.com/2013/11/14/v...-light-recall/
    So what they did was issue a big recall in 2009 for VW owners. Then in 2012/2013 Audi customers around the world put pressure on Audi and so Audi has selectively begun recalling and replacing the mechatronic units and refilling the transmission with mineral oil. First, it was Malaysia/China then the recall was extended to Australia/New Zealand, then into Europe. Audi has been unwilling to issue a recall in North America — but they know that every transmission with synthetic fluid is going to fail.
    Worse yet, most dealers say that the Quattro is a “sealed” unit (no fluid replacement) — yet Audi tells customers that it is CRITICAL that transmission fluid is changed every 40K miles. So its clear that the Audi dealer network isn’t clear about the issue or the fluid change intervals.
    WHAT YOU NEED TO DO
    * Immediately drain your transmission fluid and ensure the tranny is refilled with Audi-approved mineral oil
    * Watch out for warning lights that say your TPMS (tire pressure monitoring system) failed and that your Reverse gear no longer works (at which time your forward gears will begin slipping and the car is underivable).
    ////// 2014 B8 S4; Misano Red; DSG ; APR ECU Stage II with Ultra Throttle Charger; APR TCU; ECS Cold Air Intake; AWE Touring Exhaust with Down Pipes ; H&R rear sway bar //////
    ////// 2006 B7 A4; Black; 2.0T; 6MT; APR Stage I //////
    ////// 2004 B6 A4; Silver; 3.0; 6MT //////
    Jun 20 2015
    NC
    That applies to a different DSG unit. AFAIK the OEM fluid for the DL501 is perfectly fine.
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    Yep, seems to be an issue on the 2010-2012s. I don't think it's that common as a lot of people only post when they have a problem...but it's definitely common enough that people should be worried. It's one of the main reasons I opted for the B8.5 instead of a B8. I've heard of other issues with DSG as well so I think it's safe to say it's not the most reliable transmission. Thankfully the rest of the car is pretty fantastic
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Actually more of the 2010-2011s. 2012s have fewer issues then the two previous years.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Nov 25 2015
    Miami, FL
    Quote Originally Posted by cspcrx View Post
    Oh ok. Thought it was more common the first 3 years, not 2
    Jun 28 2016
    US
    Couple of things. The DSG recalls that you speak of which details changing to a mineral oil is for the smaller DGS units used in VW and possibly lower end Audis. The mech unit is not what's being damaged, the electronic cabling/circuit board is becoming delaminated due to the fluid/heat generated in the gearbox. Originally Audi was replacing the full units for the S4 DGS for a similar issue, but then changed to just swapping out the circuit board controls/cables. The last part about the gearbox being sealed and life-long fluid filled... that part applies to the portion of the DSG trans that houses the actual gears, not the clutches. There's two sections and one has the sealed gears and their specific oil and the other houses the mech unit, clutches. Normally Audi will replace the clutch/mech unit fluid out every 40k or so miles. The other gearbox oil is not changed out, but can be requested by the customer... but not a lot of dealers do it.
    Jul 25 2014
    San Antonio, TX
    Quote Originally Posted by SwankP3RF3ct10n View Post
    So the recall doesn't affect B8.5 S4s?
    Active Member Two Rings Big_Daddy's Avatar
    Jul 28 2013
    '13 Audi A4 (wifey)
    Woodinville / WA / USA
    Bump
    I really want to keep my 8.5 DSG (currently with 38k) but this one issue worries me the most. trying to get as much data as possible.
    Oh what I would do for a spreadsheet, that must exist somewhere at Audi, that captures the DSG failures by VIN/year.
    Jun 20 2015
    NC
    Quote Originally Posted by Big_Daddy View Post
    Bump
    Keep the fluid and external filter changed. Then do both filters at 75k. You will be fine.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Good information.
    Jun 20 2015
    NC
    Bump
