Results 1 to 11 of 11
    May 11 2014
    United States
    Need help. Should the divorced coolant system reservoir be vented or not
    I divorced my supercharger coolant circuit and added a heat exchanger and little reservoir. My question is should that little reservoir be vented or non vented. It looks like in the awe cold front kit, their reservoir is non vented but I don't know for sure. Let me know
    Current: 2018 Audi Exclusive Nogaro Blue RS3 w/Unitronic Stage 1+ E85 ECU and Stage 2 TCU, Water/Meth Injection, Black optics, Tech, Dynamic, Drivers Assistance, RS Design Packages, Carbon Inlays, Carbon Mirror
    Past: 2014 Black S4 DSG/1999 Eclipse GSX
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    I doubt it.
    The S/C coolant circuit should never be at a point that it is about to boill
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by hckymstr19 View Post
    It is not.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Don't need to
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    May 11 2014
    United States
    Quote Originally Posted by Hofahome View Post
    Don't need to
    Great thanks alot guys. And hofahome, I just finished my setup tonight with the same heat exchanger you used. I'm going to get some data logs tomorrow. All mounted up great.
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    any picture of the reservoir installed??
    tks
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Jan 26 2015
    CO
    Excellent! Which reservoir did you use?
    May 11 2014
    United States
    I had one custom made from a mishimoto coolant can. 3" diameter and about 7" long and I have a 3/4" hose barb welded to the bottom and a 90 degree 3/4 hose barb welded to the side.
    I was so able to mount two 9" spal slim behind it for track days and really hot days. Fits perfectly.
    May 11 2014
    United States
    Here is a dropbox link to see the head on view of the heat exchanger and a pic of the reservoir. Worked out great.
    https://www.dropbox.com/sh/x1sr9unij...7-fGoJNna?dl=0
    Jan 26 2015
    CO
    Looks great! Log that bitch and post up results
    Jun 30 2015
    Look good...
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
