Results 1 to 28 of 28
    Jun 17 2007
    2007 S4
    California
    Anyone wrap or plasti dip their S4?
    I originally was going to wrap mine satin blue but I just discovered the affordability of plasti dipping. Before I pull the trigger on either I'd love to see if others have considered one or the other?
    Price for a vinyl satin blue wrap: $4200
    Price for plasti dip: $800 +$100-$300 for satin finish (CustomDipWraps in LA)
    Jul 01 2015
    Metro Detroit
    Price for the wrap sounds a high to me, but I know it varies regionally.
    Never plastidipped an entire car, but I'd be interested to hear about it if you went that route.
    Matt, Metro-Detroit, Brilliant Red '04 S4
    I have timing tools for rent
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I have done different wraps and dips, not the whole body but some accents and specific pieces, currently I am using copper and I have carbon fiber wrapped the hood roof and trunk.
    Removed pictures because "criticism".......
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    that is soo dope bro... those 6 spoke pellars 17 or 18's ? if you could drop the front rake... like i did with the b5 perches, that would be right on..
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Oct 05 2015
    Billings, MT
    18's what do you mean front rake? Coming soon, 15mm spacers, and lower springs.
    Dec 07 2009
    East Coast
    Forget the B8, keep the V8!
    Feb 29 2016
    Bellevue, Ia
    I didn't do the whole car but have done others!!
    Veteran Member Three Rings caliizaktiv's Avatar
    Dec 20 2010
    Used Oil
    East Coast
    I think I'm gonna be sick.
    07 RS4 | 03 M5 | 24 RS6p
    Senior Member Two Rings b6dolphins4's Avatar
    Aug 07 2011
    Binghamton,NY / Raleigh, NC
    Quote Originally Posted by caliizaktiv View Post
    X2
    2004 DG S4
    Mods:| JHM 93 Tune |JHM Stg 4 Clutch | 034 Light Weight Flywheel | Trexturk Cat less Dp's | Custom 2.5" Non-res Magnaflow CB | K&N Drop-in | 034 MAF hose | Apikol Snub/ Zero Gap Bracket | 034 Trans mount | JHM S.S. | JHM Knob |
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by Terry.Reese View Post
    pretty much all newer cars come with the front rake (higher gap between the wheel and fender then the rear) i have oem suspension so i switched out the front perches with b5 perches and dropped the front almost an inch... looks better imho with 0 rake
    PAST
    Current
    Mar 21 2015
    Quote Originally Posted by b6dolphins4 View Post
    X2
    X3
    Feb 29 2016
    Bellevue, Ia
    Wow ok
    Feb 29 2016
    Bellevue, Ia
    Aug 07 2011
    Quote Originally Posted by pchrist View Post
    Wow ok
    Wasn't directed towards you
    2004 DG S4
    Feb 29 2016
    Bellevue, Ia
    Ok thanks!!
    Mar 21 2015
    Ok thanks!!
    Post 3
    https://goo.gl/images/HzJdTH
    Oct 05 2015
    Billings, MT
    Yes, yes, we all know you're all about the clean OEM stock basic look. That's great, stop blasting people for wanting to be different and not the oh look another S4... it's our vehicles. .not yours, you're not going to change our minds or opinions.
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by TarlCabot View Post
    Ahh, i have lowering springs coming after the spacers.
    Can you PM me some pics? I would appreciate it. Thanks
    Oct 05 2015
    Billings, MT
    Yeah, sure. Filing your opinions with my lack or need for your approval in the same trash can.
    Aug 07 2011
    How about not posting 8 pictures of you're car to a PUBLIC car forum then?
    Don't put yourself out there if you can't handle criticism....
    2004 DG S4
    Oct 05 2015
    Billings, MT
    Well someone asked for help, But ok, whatever. Noted with that "criticism"
    Registered Member One Ring Nik.goodnow's Avatar
    Jul 30 2016
    '02 VR 6 Jetta '03 Dodge Ram 1500 '01 Subaru Legacy
    Pawling NY
    Dipping the whole car comes out great as long as it's done right, protects your paint for years too ;) Only thing I don't like is the black dip is tough to clean if you get actual dirt/mud on it. But the clear coats should help with that. Much better "bang for the buck" and you can dip over old dip for repairs or color change. I'm about to dip my whole mk4 jetta and wheels in 2 weeks or so. I'll post a pic or 2 when its done lol
    Veteran Member Three Rings Kevinskir's Avatar
    Feb 03 2010
    Portland Oregon USA
    I dipped my A4 last year, went with Volcano Red and my post about it can be seen here http://www.audizine.com/forum/showth...-Dipped-my-car
    It took almost 2 days, with cleaning and prep. Taping off everything and learning how to make edges cleaner, and not having overspray was something I learned after I finished doing it myself. If you are having a shop do it professionally, I would ask to see if they have any cars you can look at, and examine the trim and other areas (between the doors) to see if there are tears or overspray. Their price seems really really high honestly, and I would ask for a breakdown on their costs. If their material cost is more than $5-600 I would look into buying the material yourself from dipyourcar.com
    I had a blast doing it myself, learned a lot, and it would still be on my car today except I sold it and the buyer wanted it back to black. Took about 1.5 hours to get it all peeled off and cleaned, and could not be happier with the results. There are a lot of people who hate on it but if that is the route you want to go, I say go for it!
    2008 Ibis S4 Avant- Driving in a Unicorn, moving by Llamathrust
    Stasis Exhaust with Piggies| JHM 91 Tune | JHM Short Shifter| PSS9 Coilovers|
    2007 Sprint Blue RS4- Sold and off to a new stable
    2007 Volcano Red Plasti-dipped A4 2.0T Quattro - Sold
    Oct 11 2007
    Suburbia
    Had my old RS4 professionally dipped satin clear, lasted almost 2 years and the dealer that took it in on trade has it currently offered still intact.
    Oct 11 2007
    Suburbia
    Big ups to Boston Dip and Detail, Phil is the man!
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    Quote Originally Posted by WinterRunner View Post
    That looks great, love it
    Feb 04 2016
    London
    Terry that's nasty. You know what they say... money can't buy taste.
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by Hooblah View Post
    you know, whatever guys.. I am out.
