Hello Audiziners. So I was logging my mass air flow rate with the torque app and It seems im only getting around 140-145 g/s max. I was doing both 2nd and 3rd gear pulls. Im thinking clogged cats since I was getting cat efficiency cel before. I had it coded out with a tune. So far ive changed Ignition coils, spark plugs, mass air flow sensor, pcv, a few vacuum lines, and the air filter. Although the car feels better I cant seem to get above 145 g/s in this hot California weather. Soooo with that said, what do you guys think? Anything else I should check?
Btw this is a 03 A4 3.0 quattro with 6 speed.
