Results 1 to 17 of 17
    Feb 08 2016
    Portland
    A6/7 3.0 356mm & 345mm Big Brakes for A4 B8/8.5
    Due to moving the A4 on for something more spicy my BBK is now redundant.
    Now I know people will prob chirp in saying this isn't a true BBK which I agree it isn't. It is however a Huge upgrade to the small B8 brakes which are 320mm this allows 356mm rotors
    Everything has been stripped and checked as well as test fitted to prove it fits a B8/8.5
    This is a 100% bolt up kit. I physically bolted one up this morning for the picture below. Zero issues inc being able to use stock b8/8.5 brake lines too
    You might need spacers dependent on what wheels you have. Some designs will, some won't need them. None are included. I don't know what wheels do or don't fit sorry. I've had them on both my A4 b8 and allroad 8.5.
    They do fit behind 18inch wheel upward. 2 people here have already done this from what I've seen here Again depends on your wheel and might need spacers/shims. Visually I would say anything from 5-20mm but that's a guess so don't hold me to that figure
    They have been painted lime green but this is only paint and not powder and can be easily removed and redone in the colour you decide. Simple aircraft stripper from Home Depot will get it done double time. Then prime and repaint. One caliper has a few marks in the paint, where pad clips have scraped, small chip on front and small amount of fluid peel round the line thread. (Not visible) (but your prob going to ditch the lime green anyway lol)
    I'd prob be up for repainting them pretty much any color you want but that will be extra cost and take a bit of time. Obviously I won't do this until payment is made
    So here's what is for sale.
    2 X A7/6 3.0 Quattro calipers I believe with 35k on but it's kinda irrelevant as I've gone through them and they are perfect piston and seal wise
    2 X A7/6 3.0 caliper carriers
    Brand new and never used Ceramic pads
    All hardware needed calipers have new slide pin bushes installed
    Bleed screws are polished and are not seized in any way
    Slide pins polished for silky smooth action
    2 X 356mm x 34mm front rotors (500miles on them only ) painted centers black
    2 x 345mm x 30mm rear rotors ( around 1000 ish miles virtually no lip)
    I was going to upgrade the rears too but didn't get round to getting carriers yet but I'll throw in some very very good S4 rear rotors around 1000 mile I think but still in very very good shape with the kit so all you need to do is get S4 carriers
    This is a bolt up kit and is huge compared to the stock set up.
    Looking for $650 or a very good offer
    I don't use PayPal as they are assholes so we will have to talk about payment. If this is the only option I have someone I can use as a go between. PayPal will be plus fees sorry
    This is way less then what I have in everything
    Shipping is down to you it might be cheaper to do it in a few large flat rates rather then all in one as its bloody heavy
    I think I could fit the following in large flat rate boxes. One box per caliper, one box per 2 rotors, 1 box for pads and hardware . I'll try and update this when I find some scales to weigh everything and see if it's cheaper in a huge box.
    Pick up is cool in Portland area. I could possible get over to Washington also
    Any question please ask I've tried to be as clear as possible with this detailed advert
    I've done all the research so you don't have to
    Thanks for looking
    And to show they 100% bolt up
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    I'm interested let's chat in PM
    Feb 08 2016
    Portland
    Provisionally Sold
    I have potentially another pair of the same calipers for sale. PM for details
    Feb 08 2016
    Portland
    SOLD
    But I do have another set available shortly.
    Just calipers and carriers this time, some good used pads included.
    Can be painted any colour you want.
    PM for details
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    do you have any s4 rear calipers?
    Feb 08 2016
    Portland
    No sorry just what I've listed
    Active Member Two Rings grumpycarguy's Avatar
    Sep 26 2016
    B8 Avant S-Line & K12 Gixxer 750
    Canada Eh!
    Hey sorry for the thread bump but I wanted to do the conversion and can't see you pircutres. I know they're sold I just want to see how it looks thanks :)
    Established Member Two Rings ofspecialk's Avatar
    Nov 06 2016
    Bump for pictures!
    Veteran Member Four Rings jaycurn's Avatar
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    I'm local and would love to check this setup out if you still have it.
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    It's a great setup.
    I run them on my s4 and love them.
    Sent from my SM-G900W8 using Tapatalk
    Feb 08 2016
    Portland
    I will have another set available soon. Drop me a PM and we can discuss what colour etc
    Feb 08 2016
    Portland
    Soon as I get them in hand I'll post up a full advert if your interested. Price will
    Be around the 575 mark
    May 22 2015
    Malaysia
    Anybody have tried using SQ5 4 pot caliper with factory fitted B8 345mm rotor?
    Jul 16 2012
    Mid-Atlantic
    A6/7 3.0 356mm Big Brakes for A4 B8/8.5
    Quote Originally Posted by suku View Post
    SQ5 has a different sized, 2-piece rotor.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    SQ5 doesn't use 4 piston calipers; they're 2 piston calipers with 380mm rotors. B8 A4 factory fitted rotors are 320mm.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    holy thread revival. Images are not working so this is a true plug and play huh?
    Ivan
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I was planning on doing this when i needed brakes, will these just bolt right up with 18" aftermarket wheels?
