Guys. For real. I've done hours of research here. I cannot get a direct answer. My front AND rear offset is not even, and both front and rear wheels are pushed to the driver side. I've seen people say "This is just how our cars are" but have seen no facts to back that up. I've seen people say my subframe is misaligned, and shifted to the left. I've loosened the rear and pushed it as much as I can, but only got about 1/16" of play, and I'm still about 1/16" off. I checked the front since there are alignment pins that you can use to shift the subframe from one side to the other, and it is already dead center.
MY CAMBER IS EVEN AND ALL MY WHEELS HAVE THE SAME OFFSET. This seems to be the #1 argument against this, but I assure you, my car was just recently aligned and all 4 corners are set to factory spec camber and toe. So.... What is going on!?
This is driving me in sane. I'm OCD when it comes to my car. I didn't notice this until after I installed coilovers and spacers on my OEM S-Line wheels, but I imagine it was like this before that and I simply didn't notice because of the wheel gap and inset wheels. My car is 2008 A4 Quattro S-Line 2.0T. My new wheels are Miro 111 19x8.5 et32, and the wheels are flush on the driver side, and tucked on the passenger side. It is visible to the eye. In front, the driver side wheel actually pokes a bit, and passenger wheel is nearly flush, but slightly tucked.
Someone please at least give me an explanation. I've seen tons of guys lowered and bagged, and in the "stance" world there's no way these guys would let their cars have uneven offsets. I'm about to say screw it and buy spacers for just the passenger side, but I want to FIX it, if that's even possible.
Driver rear: Flush
Passenger rear: Tucked
Driver front: Slight poke
Passenger front: Tucked
