Hey guys, some of you know me from the B5 world that I have been living in for the past 12 or so years. I sold my widebody 600hp Avant recently and bought a well sorted B8 S4. Currently the car has the following mods:H&R Street Performance Coil Over Kit, rear shocks upgraded to Bilsteins.
Malone Stage II tune - this is THE car that was dynoed at 415WHP and 377WTQ. (http://www.malonetuning.com/ecu-tuni...kswagen/30tfsi) -this is the car that is on their website.
Stage II supercharger pulley.
AWE tuning "cold front" coolant reservoir.
APR coolant performance system coolant tank.
AFCO Ford GT500 double pass heat exchanger.
USP Motorsports intake.
All interior lighting converted to LED
Carbon fiber mirror housings.
Debadged with painted and cleared taillights (light smoke, not overdone, flawless finish.)
RS4 black front grille.
P3 cars vent gauge with boost, battery voltage, air temp, exhaust temp, 0-60, coolant temp, and ignition timing.
Audi RS4 steering wheel.
034 motorsports transmission insert.
034 motorsports differential inserts.
034 stainless steel downpipes.
Opt7 Fluxbeam LED foglight bulbs.
Cross-drilled rotors with OEM pads. 84k miles.
AEM MAP/MAF based progressive methanol injection.
Titanium wheels with Michelin Pilot super sport tires 255-35-19
SPEC stage 3+ single disk clutch with new OEM flywheel
The car runs and handle well but I feel like it has more on tap so I would like to hear more on dual pulley setups. I am planning to install the JHM Overdrive lightweight crank pulley soon. Is there anyone doing custom tunes for dual pulley setups or is it just being added to existing software and still seeing noticeable gains? Thanks for any insight on my list of mods and what can be improved on. I plan to keep this car for a while and if you know me you know I will be trying to make a solid all around daily driver that performs to its peak potential.
