Results 1 to 8 of 8
Thread: chipwerke help
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    chipwerke help
    hey guys first off sorry for posting in this area but my area is kinda worthless :( I drive a 2010 a6 3.0t and I installed a chipwerke pro yesterday. I didn't immediately feel it at all, drove for about 5 miles, then for about 10 and still couldn't tell. Then I drove 200 miles home from seattle and maybe it felt faster up top but it was still hard to tell. After more driving it around last night I think I could feel it but I still don't know? I mean it feels fast but I figured I would instantly feel a difference. Is this normal?
    2012 Q5 2.0T
    2010 A6 3.0T
    2004 A4 Avant 6spd 1.8T (SOLD)
    1998 A4 quattro (SOLD AND MISSED)
    2006 Suzuki sv650
    Mar 21 2015
    Did you clear codes with vcds or disconnect the battery for a bit?
    Theres a huge CW thread in the B8 S4 side, read up.
    Junior Member Two Rings
    Feb 01 2016
    Northern VA
    I know what you mean. I have a b8.5 s4, but purchased an A6 chipwerke. I dont feel any significant gains. I reset my battery and everything too. Can anyone confirm that it should work? If not, would you be open to a trade?
    Sent from my SAMSUNG-SM-G925A using Audizine mobile app
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by seanentrust View Post
    Make sure it's on the correct setting for your octane and reset the ecu if you haven't. Octane plays a big role, if your on 91 you will be limited in power. I add 4 gallons of e85 to my tank and you can feel a difference.
    Sent from my SM-G925V using Audizine mobile app
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    yes i reset all the codes after i installed it. currently running 92 octance and it on the 4-1 setting which was reccomended
    2012 Q5 2.0T
    2010 A6 3.0T
    2006 Suzuki sv650
    Established Member Two Rings na_v's Avatar
    Jan 27 2015
    I've been told it doesn't make that much a difference for the a models only the s models feel it a lot
    Current : 2013 S5 Premium Plus | Glacier White | Magma Interior | DSG | ADS | Sport Diff | Carbon Atlas | B&O | Adaptive Lights
    AWE Track Exhaust | PUR 4OUR Forged Wheels | ECS Spacers | Carbon Imports Trunk Lip | Carbon Imports CF Mirrors | ECS Carbon Fiber Intake
    Past : 2014 Ibis White Audi A4 Progressiv | ECS Spacers | H&R Sport Springs | APR Stage 1 | RS Grille | US Millworks
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    4-1 sounds right, there should be some gains right away...with more in a day or so. You can try 5-1 but you may experience some throttle and shift delay, but it should hit harder.
    Established Member Two Rings djkyky's Avatar
    May 27 2015
    24 Audi Q3
    Estero FL
    I don't know if you got your Chipwerke to work or not but I went through the same issue. After initially installing the engine would not even run. It was trying to run way too rich. A jumper was missing so added from an old computer drive. Unhooking the battery made no difference. My son got it working for me. He used the 15 LED connector provided and locked the doors. Something about locking the doors. ?? Whatever he did worked and I felt the difference after the first five miles. I have had no issues since.
    2024 Q3
    Past A3, S4, S5, Q5, Q7
