Results 1 to 17 of 17
    Veteran Member Three Rings Dannaye's Avatar
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Tick or rattle with AC on.
    The other day i noticed a little tick rattle like sound with my AC on, once i turn the AC off the sound goes away. B8 A4 110K miles
    Jul 07 2009
    Alexandria, VA
    Noticed this recently on my allroad; will be bringing it up at next service as still under warranty. Will let you know what the verdict is.
    Present
    2018 S5 Sportback - Navarra Blue/Rotor Gray, Prestige
    2015 Toyota Highlander Limited Platnium - Family Car
    1978 Toyota FJ40 - Mustard
    1962 Porsche 356 - Red/Black
    Past
    2014 allroad - Monsoon Grey/Black, Premium +Bilstein PSS10, SPC Control Arms, 20" OEM RS5, Canvasback Liner, OEM Rear Window Sunshade Inserts, VAGCOM Mods
    2007 S4 Cabriolet 6MT (x2)
    Established Member Two Rings B8SILVA's Avatar
    Sep 13 2015
    Miami Fl
    Quote Originally Posted by Dannaye View Post
    I had this same issue and it ended up being the AC compressor giving out.
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Quote Originally Posted by S4BlackCab View Post
    Let me know what it is, my rattle went away but I'm scared of it coming back
    - - - Updated - - -
    Quote Originally Posted by B8SILVA View Post
    how much was that?
    Sep 13 2015
    Miami Fl
    - - - Updated - - -
    how much was that?
    Swapping out the entire compressor assembly came out to $750
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    My AC rattles when it's on high setting. Rattling seems like it's coming near or on top of glove box area.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Quote Originally Posted by ed@mtl View Post
    Yea same but i think mines coming from the bottom of the glove box but its definitely in the same area. Is yours minimal? Mine is pretty quiet but its an Audi and makes me think its worse than it is
    Mar 19 2004
    It's pretty loud when the setting is on high. It's not normal that's for sure.
    Established Member Two Rings Cameron_'s Avatar
    Sep 08 2015
    2007 BMW 530i
    Same problem...
    Mar 19 2004
    Funny thing is. I don't use my AC that often. I have 32 000km.
    Sep 13 2015
    Miami Fl
    Same here, I didn't often use my AC up until the summer kicked in and from one day to the next I started hearing the loud clicking noise and the compressor ended up being the verdict, And I was shy of 47k when it happened. Mechanic said to be careful having it on with the noise because the pulley for the compressor is a part of the entire belt system so if for any reason the pulley jams on the compressor it can blow the belt.
    Mar 19 2004
    Notice it's not only when the AC is on. When the fan is on as well.
    Mar 19 2004
    not too sure if u can hear it but there's whining noise from settings 8 onwards. Like how an airplane engines getting ready for take off.
    Mar 19 2004
    Turns out the blower motor was finish. Replaced under warranty.
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    How much would it be?
    Instagram @Dannaye
    Mar 19 2004
    The part is about $150.
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Oh ok I'm not worried then
    Instagram @Dannaye
