Results 1 to 40 of 46
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Pump not working?
    My car is at the shop getting tuned and a pulley installed. They pulled the charger to do the pulley. They are now bleeding the charger and saying the pump is not working. I have never had an issue or code. Would I have gotten one? Any ideas? They say they have never seen one not work
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Apr 05 2016
    Portland, OR
    The pump is not on all the time.
    I think it is on related to pressure and throttle %.
    You can short the wires to get it to run @ 100%
    let me see if I can dig up the thread where we were talking about it.
    Geoff
    Jan 04 2013
    Phoenix, az
    Ok, thanks they said it is getting really hot, the super charger is
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by cspcrx View Post
    I wasn't able to dig up much other than
    If the signal line to the pump is broken or if a short circuit
    to positive occurs in the signal line, the pump will enter
    an emergency mode delivering 100 % output. If a short
    circuit to ground occurs on the signal line, the pump will
    stop.
    If you need a new pump you might as well update it at the same time.
    Quote Originally Posted by infinkc View Post
    Instead of trying to use the stock pump, why just not switch out to an aftermarket one and wire it as above but the green wire to 12v of the aftermarket pump.
    Pump APR uses: Jabsco
    https://www.amazon.com/Jabsco-50840-...=1&*entries*=0
    Pump AMS uses: Varimax
    https://www.summitracing.com/parts/l...x4AaApnz8P8HAQ
    Pump AWE uses: Meziere'
    http://www.jegs.com/i/Meziere/680/WP...rentProductId=
    I believe the Varimax (AMS one) flows the best. This is the one I was going to go with in my setup.
    Geoff
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    You would definitely see a code if the pump stopped working.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jan 04 2013
    Phoenix, az
    Two dealers have said the same thing. The shop just keeps saying that when they open the bleed screws it's not squirting out like it normally does. It's at the dealer now. They, the dealer, said its not meant to run all the time and if there is an airpocket by the temp sensor it could cause it to not turn on. They are going to pressure bleed and check it. The dealer also said in addition to a light it would run very hot and that would cause a light.
    I will report back on what they find. I am on the stock tune profile right now because they have me freaked out that there's a problem. Sucks to go stage 2 and drive around on the stock tune!
    Trying to find any diagrams that show if there is a thermal sensor in the charger for the pump.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    RPMs need to be at 2k+ for pump to kick on...requires one person on throttle...another on bleeders.
    Jan 04 2013
    Phoenix, az
    Thanks, also does anyone know where the sensor is for the temperature? Everything I have read says it has to see a certain amount of boost, which lines up with you 2k comment, and 122 def F. Where is this temperature sensor at?
    Thanks all
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    The pump gets the reading from the MAP sensor I think.
    The below shows a pic (not my car) of the cable (broken in the case of the pic)
    If you find out the what colour wire does what could you let me know please :)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Jul 31 2007
    Boston
    Does that help?
    Feb 05 2016
    UK
    Nice one @beans912
    So the PWM signal will come via the Yellow/Blue wire then ?
    Jul 31 2007
    Boston
    Yes. That diagram is from a 14, I'm not sure if they are different from year to year. Mines a 16 but there isn't a wiring diagrams for 16's yet on shopkey
    Jan 04 2013
    Phoenix, az
    Yes it does, so it doesn't have its own sensor its getting the signal from the ecu to flip the relay. Pump is only two wires in this diagram. This is interesting because the shop, the did the work, said the pump as three wires but the illustration shows two. Curious if the preface lift, like my 2012, is different.
    Jul 31 2007
    Boston
    The pump has 3. It's the one on the middle of the left side in the picture.
    Apr 10 2007
    Beaverton OR
    Quote Originally Posted by xpoweruk View Post
    Nice one @beans912
    Looks like it.
    Is the trigger signal from the ECU 5v or 12v? That may be the key to wiring the pump to run continuously while the engine is running.
    Jan 04 2013
    Phoenix, az
    I was looking at the wrong pump. Man there is a lot of them! Never realized it.
    Feb 05 2016
    UK
    Quote Originally Posted by Jflow23 View Post
    Looks like it.
    I'm not sure if 5v or not.
    but
    If the signal line to the pump is broken or if a short circuit to positive occurs in the signal line, the pump will enter an emergency mode delivering 100 % output
    Feb 05 2016
    UK
    7
    I though the pic may be of use to you cspsrx
    Jan 04 2013
    Phoenix, az
    Very. So the pump actually sends info back to the ECU and has an internal sensor. Very interesting.
    I am hoping to hear today from the dealership that has it. I am really hopeful there is nothing wrong. I am stuck between two shops. One that did the work says the pump is not working and two dealers say if it was not working I would get codes and overheating.
    I am stuck in the middle with a huge question mark over my head not knowing if something is truly wrong with the car.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Assuming you still have the factory intercooler coolant configuration (non-divorced cooling system), then you don't need to run the pump to bleed the intercooler. Just get the engine warm, and the normal system pressure build-up will force the air (and coolant) out of the bleeder screws.
    Jan 04 2013
    Phoenix, az
    Yes intercooler system is stock right now, AMS Alpha arrives in the mail today!!!
    That is what the shop that did the tune said they do. They run the car and open the bleed screws on the supercharger to bleed it. But, when they did this coolant did not come squiring out like they normally see. This is what let them to determine the pump was not working. They said they also put their hands on the pump and could feel it was not running.
    This is what makes it so confusing. Dealers, two, say if this was the case I would have codes and other issues. I drove the car 45 minutes in 112 degree weather to the dealer after leaving the shop in bumper to bumper traffic and never had a single issue.
    Feb 05 2016
    UK
    I take it you have VCDS ?? If so logging IAT's under load will soon tell you if you have an issue,also VCDS can tell you the duty cycle of the pump when logging
    Jan 04 2013
    Phoenix, az
    Unfortunately I do not. On my list of things to buy.
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Question. Why did they remove the charger to do a Stage 2? Usually you just pull the bumper forward and not even all the way off? Was there some other issue?
    Jan 28 2013
    Quote Originally Posted by KnewJack View Post
    Some installers find it easier to pull the supercharger and put on the new pulley rather than put the front end in the service position.
    Feb 05 2016
    UK
    That is a good question KnewJack
    Jan 04 2013
    Phoenix, az
    Several do it that way, two locally told me that is the way they do it.
    Turns out they, the tuning shop, was wrong. Dealer reports it works perfectly there is nothing wrong with it at all.
    Feel so much better knowing nothing is wrong. Going out and switching the tune!!!
    Part of my Alpha cooler showed up, well part of it. UPS left one box but wants a signature for the other, that makes sense????????
    Don't think I will be going there to get it installed.
    Mar 21 2015
    ^ You can sign up for "my ups" and waive the sig online. It works great.
    Jan 04 2013
    Phoenix, az
    Thanks
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Well at least it's not me that UPS screws things up for. Or maybe they just don't like AMS.
    I'f I were you I'd find a different shop to install the Alpha cooler. It is a somewhat lengthy install and it's a very tight fit - at least it is on a B8.5.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Jan 04 2013
    Phoenix, az
    Thanks. Have one that I am looking at now and a lead on another.
    Just do not understand why they would leave the box with the pump and tank but not the one with the cooler and hoses.
    Jan 01 2016
    Tampa Bay
    It makes no sense. For me, they held the box with the heat exchanger at the hub for me to pick up. But they put the box with the pump and reservoir on a truck for delivery. They were going to let me leave with the box without signing until reminding them. Then after I tracked down the driver with the second box he told me I didn't need to sign for the second box. Makes no sense at all. This is why I use fedex whenever possible.
    S4 Build Thread
    Jan 04 2013
    Phoenix, az
    Most be something AMS is doing. But its the exact some for my shipment as well. Box with pump and reservoir were sitting on the porch and a note in the door. They are giving my the option to sign the little note so they will leave it. I hope they do that, don't want to drive down to pick it up.
    I agree, it makes no sense at all.
    Jun 28 2016
    US
    Probably the best decision you could possibly make.
    Jan 01 2016
    Tampa Bay
    It seems to be a UPS issue. The labels were marked as box 1/2 and 2/2. When tracking it, it showed both packages when I put in only one of the tracking numbers. I've had this issue with them before. That's why I usually have them hold my stuff at the hub if I need it quickly. But the hub is only 15 minutes from my house.
    Did you find a shop to do the install? You are going to really like this system. I drove the car really hard the other day and IAT didn't go over 97 degrees. And it was 94 outside. I'm taking it to the track this weekend so we'll really know how well it works then.
    S4 Build Thread
    Jan 04 2013
    Phoenix, az
    Yes talked to them today. I did not get the tool so they were looking to see if they have something that will do the same thing. Now that I am Stage2 I really need it with this damn heat in Phoenix.
    Probably going to schedule it tomorrow.
    Jan 01 2016
    Tampa Bay
    I'm done with the tool, so if the shop doesn't have one let me know.
    S4 Build Thread
    Jul 31 2007
    Boston
    In one of the other threads some one showed a way to install the rivnuts without the tool. I think it was the epl gb one
    Jan 04 2013
    Phoenix, az
    Thanks guys, they seem to feel they don't need it. If something changes I will hit you up.
    Feb 05 2016
    UK
    Quote Originally Posted by beans912 View Post
    Does that help?
    Do you have access to that info on a 2010 S4 ??
    My wiring is Yellow/red, Yellow/blue, Brown
