Originally Posted by
aluthman
I won't be able to help you with maps because I don't have any Torqbyte products. Two pumps seems like overkill for what you're doing. Why not split the one discharge and add a soleboid to the aux output to control flow?
No worries; for some reason I thought you had one. I'll have to start canvassing the forums for early adopters, or become the meth guru (Walter White?).
I thought of only using one pump, but it'll make the setup more complicated than it needs. I'm planning on triggering the post IC and post TB based on load and PSI (so I can run regular fuel on my 93 Octane tune, but also for 100+ Octane runs when I have 94 in the tank). It'll help stave off detonation with lower grade fuels.
I'm trying to figure out the best way to control the second pump, which is spraying into the turbo. I'm thinking the turbo speed sensor option might be the best way, if I can make that work somehow. If not, I'm probably going to have to go dependent on load and boost again. The idea is that that injector will only spray between 5500-7000 RPM. If I can somehow rig up a turbo speed sensor, and make it jive with the controller, it'll be much simpler; just trigger independent spray when the turbo is reaching past its peak efficiency.
Having said all of this, I'm no expert, but I'm willing to try things out. Plus, the Torqbyte guys are in Ottawa and I don't mind heading there for some insight.
