    May 11 2014
    United States
    Supercharger Coolant Circuit Volume B8.5
    Hey, does anybody know when you divorce the supercharger coolant circuit, what the estimated or exact volume is? And Im talking keeping everything stock and just divorcing the system. And this is for a B8.5. Any info would be great guys. Thanks
    Current: 2018 Audi Exclusive Nogaro Blue RS3 w/Unitronic Stage 1+ E85 ECU and Stage 2 TCU, Water/Meth Injection, Black optics, Tech, Dynamic, Drivers Assistance, RS Design Packages, Carbon Inlays, Carbon Mirror
    Past: 2014 Black S4 DSG/1999 Eclipse GSX
    Jan 28 2013
    I'm not sure I understand your question. Aer you asking how much coolant is in the stock supercharger loop? Or are you asking how much total coolant there is with an aftermarket divorced system? Sounds like the latter and hard to answer without knowing what the aftermarket reservoir size.
    Apr 05 2016
    Portland, OR
    You would want or really more so need a new res to safely divorce the systems.
    You need to make sure the SC coolant pump does not run dry. This could be as simple as a "T" line but I would suggest something more robust.
    I have no clue on coolant volume so I cannot help you in that regard.
    Geoff
    May 11 2014
    United States
    I want to know approximately what the stock supercharger loop holds. I am going to divorce the system, add a heat exchanger(will still maintaining the stock one), and adding a small reservoir. I know how much my heat exchanger and reservoir hold but would like to know an approx volume for the rest as I will be running water wetter and deionized water during the summer months so I need to know how much water wetter to add.
    Hope this clears up the confusion
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    After fitting an extra chargecooler I would guess the S/C coolant circuit holds around 3 litres.
    I think your best bet would be to fill with deionosed water & then drop 50% out to add water wetter
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
